[PIC] Interfacing camera with PIC18F452
shubham kumar
Member level 3
Member level 3
bangalore
I'm doing a line following mobile car (also differentiating the colors) using vision system. I plan to use a CMOS sensor type camera to interface with PIC.
Is it possible a USB webcam can communicate with PIC?
I have PIC18F452 and compiler is MiKroC. Does MikroC provides any functionality for camera input (matix input etc).
If you plan to differentiate colors also,then it seems like it will be using image processing a lot,which is a computationally intensive task.Most likely you will need to use MATLAB for it.This should give you your answers,for the first query.
https://www.societyofrobots.com/robotforum/index.php?topic=12720.0
Check this out....should answer your query.
https://www.edaboard.com/threads/188631/
