shubham jain
- Joined
- Jun 20, 2013
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 31
Dear sir,
I am using BMP085 SENSOR and i have C code of this sensor in Arduino but i have chosen PIC24EP512GU810 in easy pic fusion v7 development board.please help me in interfacing it with PIC.
find the C code in arduino given below.
Please reply asap.
Regards/shubham
Please reply asap.
Regards/shubham
BMP085 Test Code
April 7, 2010
by: Jim Lindblom
Test code for the BMP085 Barometric Pressure Sensor.
We'll first read all the calibration values from the sensor.
Then the pressure and temperature readings will be read and calculated.
Also attempts to calculate altitude (remove comments)
The sensor is run in ultra low power mode.
Tested on a 3.3V 8MHz Arduino Pro
A4 (PC4) -> SDA
A5 (PC5) -> SCL
No Connection to EOC or XCLR pins
#include <stdlib.h>
#include <stdio.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
#include <avr/interrupt.h>
#include "types.h"
#include "defs.h"
//#include "math.h" // To calculate altitude
#include "i2c.h"
#define FOSC 8000000
#define BAUD 9600
#define BMP085_R 0xEF
#define BMP085_W 0xEE
#define OSS 0 // Oversampling Setting (note: code is not set up to use other OSS values)
#define sbi(var, mask) ((var) |= (uint8_t)(1 << mask))
#define cbi(var, mask) ((var) &= (uint8_t)~(1 << mask))
///============Function Prototypes=========/////////////////
void BMP085_Calibration(void);
///============I2C Prototypes=============//////////////////
short bmp085ReadShort(unsigned char address);
long bmp085ReadTemp(void);
long bmp085ReadPressure(void);
void bmp085Convert(long * temperature, long * pressure);
///============Initialize Prototypes=====//////////////////
void ioinit(void);
void UART_Init(unsigned int ubrr);
static int uart_putchar(char c, FILE *stream);
void put_char(unsigned char byte);
static FILE mystdout = FDEV_SETUP_STREAM(uart_putchar, NULL, _FDEV_SETUP_WRITE);
void delay_ms(uint16_t x);
/////=========Global Variables======////////////////////
short ac1;
short ac2;
short ac3;
unsigned short ac4;
unsigned short ac5;
unsigned short ac6;
short b1;
short b2;
short mb;
short mc;
short md;
int main(void)
long temperature = 0;
long pressure = 0;
//long altitude = 0;
//double temp = 0;
ioinit();
i2cInit();
delay_ms(100);
BMP085_Calibration();
while(1)
bmp085Convert(&temperature, &pressure);
printf("Temperature: %ld (in 0.1 deg C)\n", temperature);
printf("Pressure: %ld Pa\n\n", pressure);
// For fun, lets convert to altitude
/*temp = (double) pressure/101325;
temp = 1-pow(temp, 0.19029);
altitude = round(44330*temp);
printf("Altitude: %ldm\n\n", altitude);*/
delay_ms(1000);
printf("\nCalibration Information:\n");
printf("------------------------\n");
ac1 = bmp085ReadShort(0xAA);
ac2 = bmp085ReadShort(0xAC);
ac3 = bmp085ReadShort(0xAE);
ac4 = bmp085ReadShort(0xB0);
ac5 = bmp085ReadShort(0xB2);
ac6 = bmp085ReadShort(0xB4);
b1 = bmp085ReadShort(0xB6);
b2 = bmp085ReadShort(0xB8);
mb = bmp085ReadShort(0xBA);
mc = bmp085ReadShort(0xBC);
md = bmp085ReadShort(0xBE);
printf("\tAC1 = %d\n", ac1);
printf("\tAC2 = %d\n", ac2);
printf("\tAC3 = %d\n", ac3);
printf("\tAC4 = %d\n", ac4);
printf("\tAC5 = %d\n", ac5);
printf("\tAC6 = %d\n", ac6);
printf("\tB1 = %d\n", b1);
printf("\tB2 = %d\n", b2);
printf("\tMB = %d\n", mb);
printf("\tMC = %d\n", mc);
printf("\tMD = %d\n", md);
printf("------------------------\n\n");
// bmp085ReadShort will read two sequential 8-bit registers, and return a 16-bit value
// the MSB register is read first
// Input: First register to read
// Output: 16-bit value of (first register value << 8) | (sequential register value)
char msb, lsb;
short data;
i2cSendStart();
i2cWaitForComplete();
i2cSendByte(BMP085_W); // write 0xEE
i2cSendByte(address); // write register address
i2cSendStart();
i2cSendByte(BMP085_R); // write 0xEF
i2cReceiveByte(TRUE);
msb = i2cGetReceivedByte(); // Get MSB result
i2cReceiveByte(FALSE);
lsb = i2cGetReceivedByte(); // Get LSB result
i2cSendStop();
data = msb << 8;
data |= lsb;
return data;
i2cSendStart();
i2cSendByte(0xF4); // write register address
i2cSendByte(0x2E); // write register data for temp
i2cSendStop();
delay_ms(10); // max time is 4.5ms
return (long) bmp085ReadShort(0xF6);
long pressure = 0;
i2cSendStart();
i2cSendByte(0x34); // write register data for temp
i2cSendStop();
pressure = bmp085ReadShort(0xF6);
pressure &= 0x0000FFFF;
return pressure;
//return (long) bmp085ReadShort(0xF6);
void bmp085Convert(long* temperature, long* pressure)
long ut;
long up;
long x1, x2, b5, b6, x3, b3, p;
unsigned long b4, b7;
ut = bmp085ReadTemp();
ut = bmp085ReadTemp(); // some bug here, have to read twice to get good data
up = bmp085ReadPressure();
x1 = ((long)ut - ac6) * ac5 >> 15;
x2 = ((long) mc << 11) / (x1 + md);
b5 = x1 + x2;
*temperature = (b5 + 8) >> 4;
b6 = b5 - 4000;
x1 = (b2 * (b6 * b6 >> 12)) >> 11;
x2 = ac2 * b6 >> 11;
x3 = x1 + x2;
b3 = (((int32_t) ac1 * 4 + x3) + 2)/4;
x1 = ac3 * b6 >> 13;
x2 = (b1 * (b6 * b6 >> 12)) >> 16;
x3 = ((x1 + x2) + 2) >> 2;
b4 = (ac4 * (unsigned long) (x3 + 32768)) >> 15;
b7 = ((unsigned long) up - b3) * (50000 >> OSS);
p = b7 < 0x80000000 ? (b7 * 2) / b4 : (b7 / b4) * 2;
x1 = (p >> 8) * (p >> 8);
x1 = (x1 * 3038) >> 16;
x2 = (-7357 * p) >> 16;
*pressure = p + ((x1 + x2 + 3791) >> 4);
****Initialize****
void ioinit (void)
//1 = output, 0 = input
DDRB = 0b01100000; //PORTB4, B5 output
DDRC = 0b00010000; //PORTC4 (SDA), PORTC5 (SCL), PORTC all others are inputs
DDRD = 0b11111110; //PORTD (RX on PD0), PD2 is status output
PORTC = 0b00110000; //pullups on the I2C bus
UART_Init((unsigned int)(FOSC/16/BAUD-1)); // ocillator fq/16/baud rate -1
void UART_Init( unsigned int ubrr)
// Set baud rate
UBRR0H = ubrr>>8;
UBRR0L = ubrr;
// Enable receiver and transmitter
UCSR0A = (0<<U2X0);
UCSR0B = (1<<RXEN0)|(1<<TXEN0);
// Set frame format: 8 bit, no parity, 1 stop bit,
UCSR0C = (1<<UCSZ00)|(1<<UCSZ01);
stdout = &mystdout; //Required for printf init
if (c == '\n') uart_putchar('\r', stream);
loop_until_bit_is_set(UCSR0A, UDRE0);
UDR0 = c;
return 0;
/* Wait for empty transmit buffer */
while ( !( UCSR0A & (1<<UDRE0)) );
/* Put data into buffer, sends the data */
UDR0 = byte;
