Interesting SMBUS behavior
SamV
Newbie level 6
Newbie level 6
Hopefully this is the most relevant place for this thread.
I've been working on getting an SMBUS communication with the part STTS751-1DP3F to a functional state.
The data sheet for this part can be found here: https://www.digikey.com/product-detail/en/STTS751-1DP3F/497-10724-1-ND/2404148
My problem is that when sending the digital temperature IC a 'send command' I do not receive an ACK bit. (I don't receive an ACK for any other command either)
Please take a look at the scope shot I've attached to this thread. In it you will see the SDA and SCL lines. Notice there is some sort of inverse relationship between SDA and SCL durring SDA low periods. Perhaps if I can resolve the problem depicted in the scope image then I will have successful communication with the IC. Any comments about this, or has any body every seen anything like this? I've copied my SMBus (I2C protocol if your not familiar with SMBus ) code below. Comments are welcome on the code, but I think that the code is not the problem.
Thanks All
~Sam
module SMBus(clk,sda,scl,en,count 		//,data,clksynth,count,hold
input clk;
inout sda;
input en;
output scl;
//=====simulation outputs
output count;
//output [15:0] clksynth;
//output hold;
//output [9:0] data;
//output [5:0] count;
reg sdareg;
initial sdareg = 1'b0;
reg [15:0] clksynth;
initial clksynth = 16'b0;
reg init;
initial init = 1'b0;
reg scl_;
initial scl_ = 1'bz;
wire _scl_ = scl_;
wire scl = init ? _scl_ : 1'bz;
reg [17:0] data;
initial data = 18'b011101100000001001;//data[17] = start,  data[16:10] = SlaveAddress, data[9] = Write
reg [5:0] count;
initial count = 6'b0;
reg ss;
initial ss = 1'b0;
wire sda = ss ? 1'b0 : 1'bz;
//============generate SCL======================
always @(posedge clk)begin
clksynth <= clksynth + 1'b1;
if(en)begin
scl_ <= clksynth[12] ? 1'b0 : 1'bz;
end
if(~en)begin
scl_ <= 1'bz;
end
if(count == 6'd20)begin
scl_ <= 1'bz;
end
end
reg [3:0] state;
initial state = 4'b0;
reg hold;
initial hold = 1'b0;
always @(negedge _scl_)begin
if(en)begin
if(count > 6'b0)begin
init <= 1'b1;//set SCL to high impedance before start condition
end
if(hold == 1'b1)
ss <= 1'b0;//set SDA to high impedance while waiting for ACK
else if(hold == 1'b0)begin
if(data[17] == 1'b0)//pull low (data = 0)
ss <= 1'b1;
else if(data[17] == 1'b1)//high impedance (data = 1)
ss <= 1'b0;
end
//=========state machine to shift data bits==========
case(count)
6'd0:begin
count <= count + 1'b1;
data <= data<<1;
end
6'd1:begin
data <= data<<1;
end
6'd2:begin
data <= data<<1;
end
6'd3:begin
data <= data<<1;
end
6'd4:begin
data <= data<<1;
end
6'd5:begin
data <= data<<1;
end
6'd6:begin
data <= data<<1;
end
6'd7:begin
data <= data<<1;
end
6'd8:begin
hold <= 1'b1;//wait for ACK
end
6'd9:count <= count + 1'b1;
6'd10:begin
if(sda == 1'b0)begin//continue on ACK
hold <= 1'b0;
data <= data<<1;end
end
6'd11:begin
data <= data<<1;end
6'd12:begin
data <= data<<1;end
6'd13:begin
data <= data<<1;end
6'd14:begin
data <= data<<1;end
6'd15:begin
data <= data<<1;end
6'd16:begin
data <= data<<1;end
6'd17:begin
data <= data<<1;end
6'd18:begin
count <= count + 1'b1;end
6'd19:count <= count + 1'b1;
6'd20:begin
hold <= 1'b0;
data <= data<<1;end
end
endcase
end
end
endmodule
