i am starting a project Interafcing 8928252 with enc28j60 ethernet controller using SPI.
can anybody tell me Do we need to implement tcp/ip stack for the above ethernet interface?
i hope the ethernet controller consists of inbuild functions and we need to make use of those functions?
please give me some suggesions and any links r articles regarding this?
I think you will be needing TCP/IP stack
which compiler you will be using if the compiler contains ethernet library then that means its stack is built in otherwise you need to use tcp/ip stack
hope it can help u
sohail
Good luck, you're going to have to write a TCP/IP stack for your micro. Not a trivial task it's going to be difficult for sure.
Much easier to use a PIC18F4620 (64K byte FLASH) and the stack is free from Microchip.
PS the ENC28J60 is a 3.3V IC, you're going to need a 74HC125 to act as a level converter if your processor is 5V
