Dec 22, 2018 #1 P Puppet123 Full Member level 6 Joined Apr 26, 2017 Messages 356 Helped 22 Reputation 44 Reaction score 21 Trophy points 18 Activity points 3,059 Hello, I am laying out 8 components for an interdigitated MOS layout. I am using the pattern: AB AB BA BA To add dummies, should I add B's on both sides ? Is this thinking correct ? Thank you.
Dec 25, 2018 #2 Q quyleanh Member level 3 Joined Oct 9, 2014 Messages 57 Helped 5 Reputation 10 Reaction score 4 Trophy points 1,288 Activity points 1,711 Yes. You should add B on both sides. If between each groupd has space, the dummies have the same space as well.
Jan 2, 2019 #3 R rangermad Full Member level 3 Joined Sep 11, 2015 Messages 152 Helped 30 Reputation 60 Reaction score 28 Trophy points 1,308 Activity points 1,979 I would probably do AB AB AB AB with dummies on both sides. Much depends on the preferences of the design engineer
