search the web for interviewing questions. I saw a number of questions listed from the people who interviewd there. Most often, engineers don't have time to make new question for the interview. They search the web for the questions they can ask in an interview. Even if you don't get the same question, you will have an idea of what things to expect.
One thing I have noticed is that most interviewers don't really understand what they are asking. Be assertive in your answers and don't let them intimidate you.
Interviews rally don't work. I have seen peaople who ace the interview and endup being lousy engineers and those who don't do good in the interview but perform really good doing the job.
here is a sample. I'm sure there are lots more on the net:
The following questions are used for screening the candidates during the first interview. The questions apply mostly to fresh college grads pursuing an engineering career at Intel.
Have you studied buses? What types?
Have you studied pipelining? List the 5 stages of a 5 stage pipeline. Assuming 1 clock per stage, what is the latency of an instruction in a 5 stage machine? What is the throughput of this machine ?
How many bit combinations are there in a byte?
For a single computer processor computer system, what is the purpose of a processor cache and describe its operation?
Explain the operation considering a two processor computer system with a cache for each processor.
What are the main issues associated with multiprocessor caches and how might you solve them?
Explain the difference between write through and write back cache.
Are you familiar with the term MESI?
Are you familiar with the term snooping?
Describe a finite state machine that will detect three consecutive coin tosses (of one coin) that results in heads.
In what cases do you need to double clock a signal before presenting it to a synchronous state machine?
You have a driver that drives a long signal & connects to an input device. At the input device there is either overshoot, undershoot or signal threshold violations, what can be done to correct this problem?
What are the total number of lines written by you in C/C++? What is the most complicated/valuable program written in C/C++?
What compiler was used?
What is the difference between = and == in C?
Are you familiar with VHDL and/or Verilog?
What types of CMOS memories have you designed? What were their size? Speed?
What work have you done on full chip Clock and Power distribution? What process technology and budgets were used?
What types of I/O have you designed? What were their size? Speed? Configuration? Voltage requirements?
Process technology? What package was used and how did you model the package/system? What parasitic effects were considered?
What types of high speed CMOS circuits have you designed?
What transistor level design tools are you proficient with? What types of designs were they used on?
What products have you designed which have entered high volume production?
What was your role in the silicon evaluation/product ramp? What tools did you use?
If not into production, how far did you follow the design and why did not you see it into production?
