integration of radiation pattern HELP needed
asturias
Member level 3
Can someone help me to integrate an antenna radiation pattern with a high accuracy in matlab?
micky74
Member level 1
Could you tell me specifically what you are trying to do here?
asturias
Member level 3
After simulating a structure in HFSS or CST I get the radiation pattern in terms of E-field. What I need is to integrate this component so as to computer a factor. Since the E-field is a function of theta,phi the integration should be done in spherical coordinates. The input values are 2 D matrixes representing the values of E-field in terms of theta,phi( E=f(theta,phi)).
