I would like to understand noise calculations in more detail. For an amplifier operating for a signal frequency in the range of 1MHz to 5 MHz, how should I calculate input referred noise.
Is the spot noise @ (1MHz - 5 MHz) the noise that I should use to calculate the SNR or the integrated noise from (1Hz to 5 MHz) the number I should keep in mind.
Could someone please explain the significance of spot noise and integrated noise and what is important while doing noise simulations and calculations for an amplifier.
Thanks.
