Actually I'm using a double relay to change direction and a power mosfer or another relay to switch on and off motor current. Problem is that relays, expecially when i use 2, generate a lot of noises and disturb my control logic.
when i use only one relay everything works fine but i intendet to remove also this relay.
i'm considering MSK series it is interesting.
Waht do you think about IR3220 from International Rectifier? i think it could be a good solution, only 7 amperes unfortunately.
