therealpaulie
Newbie level 6
Hi all,
I have a dual port RAM. Two inputs and two outputs. The RAM is a entity.
Ok. I want to access (R/W) port A in the processing module and port B in the communication (RS232-serial) module. The idea is that I don't want to build a memory module that have DataInA, DataOutA, AddrA, DataInB, DataOutB, AddrB. (actually I have several RAMs and it doesn't look practical to have 30 outputs and 30 inputs for an RAM module).
How could I break one RAM in two so is once instantiate in module #1 (only the port A related signals) and once in module #2 (only the port B related signals).
Can you also recommend which is a good way to deal with double port RAM?
Thanks,
Paul
Thanks,
Paul
