InstallScape error for Cadence610
kumarghz
Member level 5
Penang, malaysia
installscape fedora
Dear members,
I tried to install Cadence IC610 on my Fedora. I having problem when installing Installscape.
1. How to identify that I do have installScape on my CD?
2. If dont have where I can get it? other than cadence website.
My error is as below;
Do you want to install InstallScape for lnx86[y/n]:y
It is recommended that you install InstallScape
outside the Cadence installation hierarchy
and include the ~iscape/bin in your PATH environment variable.
Type the path to InstallScape installation directory [ (q to quit)]: /home/eda/installscape
InstallScape installation directory: /home/eda/installscape
Extracting InstallScape version
for platform lnx86 in /home/eda/installscape
SETUP.SH: line 814: uncompress: command not found
Could not install InstallScape in /home/eda/installscape
You must have write permissions to /home/eda/installscape
There must be atleast 80 MB of disk space available in
/bin/tar: This does not look like a tar archive
/bin/tar: Exiting with failure status due to previous errors
Exiting...
[kumar@kumar CDROM1]$
Please help
regards,
Kumar
R00KIE
Full Member level 2
Portugal
cadence iscape disk space
This line tells you the problem "SETUP.SH: line 814: uncompress: command not found".
You don't have the "uncompress" executable in your system. Try to use yum to install it.
