satishgra
Member level 3
OS : ubuntu 11
I have installed ICFB 6.1 using installscape.
I dont know how to launch it
somebody can kindly help me out in doing the setup
Thanks in advance
---------- Post added at 16:53 ---------- Previous post was at 16:27 ----------
I had also run the following command :
/CAD/Cadence/IC61/tools/bin# lmgrd -c /home/sgrandhi/Downloads/Cadence_IC610/ic610_1.dat -l /tmp/cadence.log
My log file has lot of error messages
The license server manager (lmgrd) running as root:
This is a potential security problem
and is not recommended.
Can't make directory /usr/tmp/.flexlm, errno: 2(No such file or directory)
Can't open /usr/tmp/.flexlm/lmgrdl.2746, errno: 2
"sgrandhi-Inspiron-1545": Not a valid server hostname, exiting.
Valid license server system hosts are: "computer"
Using license file "/home/sgrandhi/Downloads/Cadence_IC610/ic610_1.dat"
Can't remove statfile /usr/tmp/.flexlm/lmgrdl.2746: errno No such file or directory
---------- Post added at 17:41 ---------- Previous post was at 16:53 ----------
Some more progress.....I found a beautiful link which explains cadence ICFB installation
Install Cadence 6.1 on Ubuntu 10.04 » getglitched.com
But, now I am facing the following issue....kindly someone help me out
root@sgrandhi-Inspiron-1545:/home/sgrandhi# cadence
root@sgrandhi-Inspiron-1545:/home/sgrandhi# icfb &
[1] 9080
root@sgrandhi-Inspiron-1545:/home/sgrandhi# ERROR: $OA_HOME/bin
(/CAD/Cadence/IC61/bin)
is not a valid OA bin directory.
Check your OA installation or update the value
of OA_HOME to point to a valid OA installation.
See the "OpenAccess Installation and Configuration Guide"
for more information.
ERROR: Unable to set OA shared library path.
---------- Post added at 18:22 ---------- Previous post was at 17:41 ----------
Some more progress......................
Now, OA path problem is also solved. But, one more new prob has arised
if I say, ICFB & @ the prompt, i see the following issue
\e request 12 error 3 serial 1676
\e Display :0 Error "BadWindow (invalid Window parameter)"
\e request 2 error 3 serial 1677
\e request 2 error 3 serial 1678
can somebody help me with this
OS : ubuntu 11
Thanks in advance
[1] 9080
