Installation Cadence IC 5.0.33 on Debian Etch
ing_israel
Newbie level 3
cadence debian
Hi, I read lots of forums, try everything you advise! but I can't install Cadence, I see the problem that is in all the forums Softload but I don't know what to do. I try with export LD_ASSUME_KERNEL = 2.4.1 or 2.2.5 etc.. but the same error, please I see some people can installed on Debian please help me.
Specify path of install directory \c
[OR type [RETURN] to exit]: \c
/cadence
Directory /cadence does not exist. Create? [y/n]: \c
y
Creating directory /cadence
\c
Setting up softload for lnx86 in /cadence
\c
The following tar errors were detected:
\c
/bin/tar: Removing leading `/' from member names
Could not set up SoftLoad in /cadence\c
You must have write permissions to install directory \c
and all its subdirectories
and atleast 10 MB available disk \c
space in install directory.
\c
cadence softload
Try to extract SOFTLOAD.TAR manually
tar xvf SOFTLOAD.TAR in directory where you plan to install CADENCE, then from this directory run ./softload and follow the instruction.
Rgds
softload.tar
I solved this problem by editing the softload script -- replacing 'tar' with 'tar -p'. Then run the script with root or fakeroot.
debian cadence virtuoso
Excelent, finally someone hep me!!! Thanks!!! I will try installing softload first...
how to install cadence softload as other user
I have the same problem, I substitute the tar with tar -p on SETUP.SH but nothing happens...
tar xvf SOFTLOAD.tar, and run it form SETUP.SH, but nothing happens...
./softload and on the menu chose my CDROM, etc ,etc.. but I don't find the way to install this application... please help me
Please another idea.. I can't install Softload/Cadence in Debian Etch...
Please a link or something that can support me...
could not set up softload in cadence
in SETUP.SH, there are 3 "tar -xf" commands.
edit the last two to read "tar -Pxf". Note its a capital P. run ./SETUP.SH
cadence ic debian
Hello, I had the same problem in ubuntu 7.10, solved :), now the installation stops due to the following problem
symbol errno, version GLIBC_2.0 not defined in file libc.so.6 with link time reference
I've seen this problem in many forums, for which the solution is
export LD_ASSUME_KERNEL=2.4.1
still doesn't work, I looked for the kernel I have (uname -r) and put that but still doesn't work, do I have to install the GLIBC??? if so, the oldest I found wasn't exactly the 2.0, it was the 2.0.7, does it work any ways??? is the installation of GLIBC the solution to my problem??? please help!!!!
Thkx
cadence on debian
Use low version KERNEL or u can't use export LD_ASSUME_KERNEL=2.4.1 unless u complier this characteristic yourself but it's complex.
cannot start softload cadence linux
Excelent !!! this works fine for my Debian Etch, Thanks !!!!
add P for the last two tar commands... topic closed!!!!!
