RepulsiveStyler
Newbie level 5
I am using CHQ1838D module as my Infrared Receiver, while testing the circuit since its an active low device I am getting an output of almost 5V and when it is blasted with 38 Khz Infrared Signal, the output voltage varies from 3.69V to 4V. My aim is to calculate the RPM of the rotating object by capturing this ouput pulse from the receiver module over the period of a second. PIC18F452 is utilized with RA4 port is configured as input and T0CKI is configured to count when High to Low. But T0CKI is not able to count. What am I doing wrong?
And since I am using Development board HP 488 00 3, it only has PORTA and PORTB on board screw terminals where I can connect external circuits. Due to the requirement of my project, I am using PWM module at PORTC. How am I suppose to get the PWM output since there are no screw terminals? Are there other pins I can connect my Infrared Transmitter?
