Information about analog cable TV design
m229
Iran
Hi all;
i want to know about designing an analog catv (cable television) and its important parameters.
Re: analog catv design
Cost is #1. Intermodulation distortion is the technical biggie. Things like 5-tone intermod tests. Then probably heat dissipation/reliability.
dear biff44;
thanks for u'r reply; can u introduce me a document for this topic.
thanks alot
m229
Just search around on "multi tone intermodulation". Here is one:
The problem in CATV is that you have 200 RF channels, right next to one another. So, a 2 tone intermod test is a little too easy for the components. You put in 3 or 5 tones, and see what the highest intermod products are. Multitones can constructively add or subtract to really have a big peaking factor--really stressing things like amplifiers.
If you have high intermods, one or more CATV channels interfer with a desired one, and the system stops working.
analog catv design
how about the DVB_C tuner
h**p://www.maxim-ic.com/appnotes.cfm/appnote_number/728
But 2-tone test is very importent test to caracterize equipment.
from 2-tone can calculate IP3 and from IP3 value you can
recalculate multiton situation and different wanted
carrier vs inteference dynamic.
Two-tone give steady spuriose/IM and easy to measure
but > 2 tone test give spuriose with sum of cycling envelopes,
give lower RMS-value but still high peak value etc.
and more carrier give lower RMS-value on each IM-product, but
envelope is more and more puls shaped and still
high peak value.
you can calculate ruffly 10 * log10(number of carriers / 2) = give how
many dB lesser signal strengt each carrier compare to two-tone test
and approx. same IM and spuriose RMS-level floor.
for example you measure IM-product -36 dBm on 15 dBm output
in two tone from amplifier and can calulate IP3
IP3 = (dBc/2) + dB above 0 dBm
here:
dBc = (36 + 15 = 51 (differense between carrier and IM-product, C/I)
and
IP3 = (51 dBc / 2) + 15 dBm = 40.5 dBm IP3
from this value can calculate in four carrier situation
ie 10 * log10( 4 / 2 ) = 3dB lower each carrier compare
to two tone test for approx. same IM-product RMS-value
(-36 dBm)
(ie 3 dB lower/carrier each doubling number of carrier)
- total output power is a constant and spread out of number
of carriers
if peak-value on IM is importent (depend of type of modulation if adjecent
channel affected on this or not), you need calculate 20 * log10( number
of carrier / 2)
(ie 6 dB lower/carrier each doubling number of carriers)
this i a ruffly calculate, but works well in many cases..
if you not have equal level of carrier, you count strongest
carrier (represent minimum 3/4 of total power) and
skip carrier 6-10 dB lower on strongest carrier
in calculate-process
if you know systems IP3 value, and know allow max level
of IM-products in dBm and want 2*carrier level and C/I,
you can calculate:
IP3 = +67.5 dBm (yes is a strong amplifier)
IM = -36 dBm
2xcarriers = ?
and try formula (and hopfylly written right now)
2xcarrier = ((2 * IP3) + IM) / 3 = ((2 * 67.5) + (-36)) / 3 =
= 33 dBm * 2 carrier
and C/I_two_tone = 33 + 36 = 69 dB
and using formula early to recalculate to multicarrier system.
Ie. four carrier = 30 dBm each, eight carrier = 27 dBm each carrier etc.
If IM peak is more importent:
four carrier = 27 dBm each, eight carrier = 21 dBm each carrier etc.
- but still ruffly calculate.
common used formula for calculate C/I in eqvidistant multitone
situation and spuriose free dynamic is importent factor, use:
C/I_total_dBm = C/I_2_tone_dB - 6 dB + 10 log10(x)
(C/I = carrier over interferences)
there 'x' are
n carrier x 6dB + 10 log10 (x)
2 0 dB
3 1 6.0 dB
4 2.3 9.6 dB
5 4.5 12.5 dB
6 7.5 14.8 dB
7 11.5 16.6 dB
8 15.5 17.9 dB
9 20 19.0 dB
10 26 20.1 dB
11 33 21.1 dB
12 40 22.0 dB
13 48 22.8 dB
14 57 23.6 dB
15 67 24.3 dB
16 77 24.9 dB
n > 16 ~ (3/8) n^2 6 dB + 10 log10((3/8) n^2 ) dB
( why I not can use old fasion way 'whitespace' to format list
and fractal in formla - list above collapse now, 'submit' take away
all exept one withespace betwen words in text - and i already spent
for much time to writing text... - if possible fix it, educate me how!!!)
for equidistance carrier in frequency and same level
on all carrier
On a 67.5dBm IP3 amplifier you can give out 8.1 dBm * 16 carrier
and IM below -36 dBm in all time (44.1 dB C/I Spur-Free Dynamic Range)
and 200 carrier give -8.7 dBm/carrier and 27.3 db C/I SFDR
ok, answer is litte messy - going from simple and fast answer
to little more accurate answer in writing process... :*)
Sounds like you have never actually made the test! Go try it, and see if you still believe in the math predictions.
analog catv design
You have to register first, then check the technical library. Or you can ask c-cor for their "CATV Pocket Guide".
Hello, you'll find useful information here:
h**p://www.scatmag.com/technical.htm
h**p://www.cabletv-4u.com
h**p://www.catvnet.com.ar/ -> good site in Spanish
See algo the AGILENT AN1288-4 "How to Characterize CATV Amplifiers ...."
I've built several CATV, MATV and SATV amps, I think IP3 theory is not very useful for them, you only have to take a look at the output spectrum of a real CATV amp with only 15-20 carriers to see a nice poltergeist !
A CATV amp is basically a chain of several gain stages + final power stage.
You can find big differences if you use as intermediate amplifier, for example, a modern MMIC with P1dB=18 dB and IP3=29 dBm, or an old BJT with IP3=20 dBm. The last works better, very better. Why ?
Bye
Dear all (that reply to this topic)
thanks alot;
but i have some other questions.
u know that many equipments are using in analog cable television broadcasting for example modulators, line extender amplifiers, tapoffs, splitters, distribution amplifiers, combiners and etc.
and for delivering a well signal to the user in home (for example a good analog television signal) we should use good equipments.
and for choosing good equipment, we should know the important parameters for cable tv design and their values.
so, if u know, i want to know this important parameters (for choosing good equipments).
thanks
m229
