Can you tell me how can i define floquet port because when i define this, it gave me an error that you have define lossy material and port shouldn't touch two different material.
you need to build vacuum extensions blocks on each port (to get away from the structure analyzed) you need also to deembedd the reference plane from the port to the surface where you initially tried to define the floquet mode port
I think that you can built an infinit array by an element of antenna in Hfss, there is a fonction in this software which permit you to creat an arbitrary array from one.
Can you tell me more abt that function because right now i have design the unit cell and set the bopundary as Master-Slave to simulate for an infinite plannar array. and upper face as radiation Boundary.
