[SOLVED] Inductor Design with 50 to 200 hz
chitikivenu
Hai all.
I am new to inductor design Please help me to design inductor.
Input voltage = 100v
input current = 3A
inductance L = 613 mH
frequency f = 50 to 200hz
Please help me to find the correct core, number of turns, core area, window area.
thank you all
I suggest you use CRGOS laminate or a Microwave Oven Transformer if low efficiency and cheap is ok., but first define BUDGET Size & acceptable losses per kg of weight which determines quality and thickness (sub mm) and number of layers of iron laminates.
