advantages of mosfet over bjt
The bipolar junction transistor (BJT) has traditionally been the analog designer's transistor of choice, due largely to its higher transconductance and its higher output impedance (drain-voltage independence) in the switching region.
Nevertheless, MOSFETs are widely used in many types of analog circuits because of certain advantages. The characteristics and performance of many analog circuits can be designed by changing the sizes (length and width) of the MOSFETs used. By comparison, in most bipolar transistors the size of the device does not significantly affect the performance. MOSFETs' ideal characteristics regarding gate current (zero) and drain-source offset voltage (zero) also make them nearly ideal switch elements, and also make switched capacitor analog circuits practical. In their linear region, MOSFETs can be used as precision resistors, which can have a much higher controlled resistance than BJTs. In high power circuits, MOSFETs sometimes have the advantage of not suffering from thermal runaway as BJTs do. Also, they can be formed into capacitors and gyrator circuits which allow op-amps made from them to appear as inductors, thereby allowing all of the normal analog devices, except for diodes (which can be made smaller than a MOSFET anyway), to be built entirely out of MOSFETs. This allows for complete analog circuits to be made on a silicon chip in a much smaller space.
Some ICs combine analog and digital MOSFET circuitry on a single mixed-signal integrated circuit, making the needed board space even smaller. This creates a need to isolate the analog circuits from the digital circuits on a chip level, leading to the use of isolation rings and Silicon-On-Insulator (SOI). The main advantage of BJTs versus MOSFETs in the analog design process is the ability of BJTs to handle a larger current in a smaller space. Fabrication processes exist that incorporate BJTs and MOSFETs into a single device. Mixed-transistor devices are called Bi-FETs (Bipolar-FETs) if they contain just one BJT-FET and BiCMOS (bipolar-CMOS) if they contain complementary BJT-FETs. Such devices have the advantages of both insulated gates and higher current density.
BJTs have some advantages over MOSFETs for at least two digital applications. Firstly, in high speed switching, they do not have the "larger" capacitance from the gate, which when multiplied by the resistance of the channel gives the intrinsic time constant of the process. The intrinsic time constant places a limit on the speed a MOSFET can operate at because higher frequency signals are filtered out. Widening the channel reduces the resistance of the channel, but increases the capacitance by the exact same amount. Reducing the width of the channel increases the resistance, but reduces the capacitance by the same amount. R*C=Tc1, 0.5R*2C=Tc1, 2R*0.5C=Tc1. There is no way to minimize the intrinsic time constant for a certain process. Different processes using different channel lengths, channel heights, gate thicknesses and materials will have different intrinsic time constants. This problem is mostly avoided with a BJT because it does not have a gate.
The second application where BJTs have an advantage over MOSFETs stems from the first. When driving many other gates, called fanout, the resistance of the MOSFET is in series with the gate capacitances of the other FETs, creating a secondary time constant. Delay circuits use this fact to create a fixed signal delay by using a small CMOS device to send a signal to many other, many times larger CMOS devices. The secondary time constant can be minimized by increasing the driving FET's channel width to decrease its resistance and decreasing the channel widths of the FETs being driven, decreasing their capacitance. The drawback is that it increases the capacitance of the driving FET and increases the resistance of the FETs being driven, but usually these drawbacks are a minimal problem when compared to the timing problem. BJTs are better able to drive the other gates because they can output more current than MOSFETs, allowing for the FETs being driven to charge faster. Many chips use MOSFET inputs and BiCMOS outputs.
