DigitalDeath
Junior Member level 1
When using the ADS component tuning feature you can tune values of components but usually the values you arrive to are not available and you need to go manually and tune them to standard values. Genesys has a feature where you can select the tuning values to be a percentage, a step size or standard values including the precision %. Is there a way to do that or assign a vector/list of numbers where you can write standard values that can then be used as the values available for the tuning?
Thanks.
Thanks.
