[SOLVED] In 16x2 LCD, how to refresh the values at point only other value remains stable
thannara123
India
In 16x2 Lcd ,how to refresh the values at point only other value remains stable
In 16x2 Lcd ,how to refresh the values at point of cursor only other value remains stable .
For example :
LCD will display as follows .
Volt : 00 V
Current : 0.) A
In this example 00 in first line and 0.0 in second line data only will vary by refreshing .And the other string (data) will be stable ?
it need for an ammeter and volt meter project https://circuits-collection.blogspot.in/2015/12/microcontroller-based-ammeter-and.html
Re: In 16x2 Lcd ,how to refresh the values at point only other value remains stable
Depends on your way to write data to the LCD. It's well possible.
When i try it by the following function
 void gotoxy(unsigned char  x,unsigned char y)
 if(x<40)
  if(y) x|=0b01000000;
  x|=0b10000000;
  lcd_cmd(x);
the whole second line will refresh and repeat the line once again . :-(
Can i get a sample ?
No. The command only positions the cursor, it doesn't print.
But to refresh a specific a character, you'll set the cursor to the very position, not the begin of line. Then print exactly one character.
look for instruction "SET DDRAM ADDRESS".
Try this .hex file.
  • Voltmeter and Ammeter.rar
It's already used in post #3.
Try this .hex file.
Off-topic post. The OP is asking for a code example or explanation.
I have used the same circuit and made the code using mikroC PRO AVR Compiler. If OP needs Code then I can post the mikroC PRO AVR Code.
Try this .hex file.
sorry ,I want to do my-own for learning purpose
The main code is as follows
lcd_init();
string("Volt ");
lcd_cmd(0xc0);
string("Amp : ");
then i want to display the
lcd_data(volt);
after volt in first line
in second line
lcd_data(current;
Example : code :
lcd_init();
string("Volt ");
lcd_cmd(0xc0);
string("Amp : ");
while(1)
   lcd_cmd(0x80 + 0x08);
    string("Val_1");
    lcd_cmd(0x80 + 0x48);
    string("val_2");
    __delay_ms(100);
here the first refresh the 'vollt' againg displayin at the 0x0D DDRAM loaction .Please see the problem in proteus .
the problem was after first displaying again the displaying the first content .
  • proteus.rar
Line 1 address starts at 0x80 and line 2 address starts at 0xC0.
If you want to write at column 2 of line 1 then you have to use LCD_Cmd(0x82); and then use LCD_String().
If you want to write on line 2 column 3 then you have to use LCD_Cmd(0xC3); and then use LCD_String().
yes I did that the above program .but the lcd whole data will be refreshing :bang:
The code you posted in post 9 is correct. What do you mean by whole display refreshing ?
please see my first post .sorry for my bad English and explanation
Show the code you are using to form the Val_1 and val_2 strings.
void main(){
    TRISB = 0x00;
lcd_init();
string("Volt ");
lcd_cmd(0xc0);
string("Amp : ");
while(1)
    string("Val_1");
    string("val_2");
    __delay_ms(100);
Where are you forming the strings Val_1 and Val_2 ? How are you converting the volt and current values to strings ?
See here https://circuits-collection.blogspot.in/2015/12/microcontroller-based-ammeter-and.html
here am using avr but now i it converting into pic .
My problem is not value convertion or anything else .
I want to refresh the values in specified loaction of DDRAM only .other loaction values remain same . dont want refresh or blink ,means stable .
Without seeing the full code that you are using you won't get much help. Just post the latest code you are using.
Please post the real code instead of incomplete arbitrary snippets.
Running the simulation in post #9 reveals that the posted code is only loosely related to the actual program flow.
Overwriting a line of text with the same content doesn't cause blinking, not on on a real LCD display and apparently neither in Proteus.
Show your string() function code. I suspect that it has included LCD_Clear() function and hence you are seeing blinking.
