Forlinx
Member level 4
The OKMX6DL-C development board is a complete evaluation module (EVM) for NXP’s iMX6DL processor, which can operate at 1.0 GHz and features the most efficient ARM Cortex-A9 core, providing various memory interfaces and enhancing the flexibility and convenience of the board to connect peripheral devices. The board is ready to run Linux and supports industrial operating temperature range from -40 to +85 Celsius.
The OKMX6DL development board employs the FETMX6DL-C CPU Module as the System on Module (SoM) controller board by populating the CPU Module on its base board through 2mm pitch 320-pin stamp hole interface.
The carrier board was designed as a 4-layer PCB and on-board connectors such as Gigabit Ethernet, CAN bus, parallel camera, WIFI&BT, etc. What's more, the CPU featured MIPI, MLB and EMI are also drawn out. Tested by EMC and high&low temp to guarantee the SoM to run stable in harsh working environment.
More information may be found at the Forlinx i.MX6 SBC product page and announcement.
