IMPULSE TRAIN GENERATION IN MATLAB...
Nosheen
Member level 1
impulse train matlab
an anyone help me generate an IMPUSLE COMB(impulse train) both in time and freq domain....
let the sampling period be Ts=0.00025 or Fs=4000 , next 2Fs,3Fs and so on...
kindly help me plot this impulse train and its FFT in MATLAB
thanx in advance
mondunno
impulse train in matlab
>> Ts = 0.00025;
>> Len = 16;
>> impulseTrain = ones(1, Len);
>> n = 0:Ts:Ts*(Len-1);
>> stem(n, impulseTrain);
>> xlabel('n ----->')
    Nosheen
mondunno
matlab impulse train
>> freq = fft(impulseTrain, Len);
>> stem([(0:Len-1)/(Len*Ts)], abs(freq))
it shows a peak at 0 frequency, that result is correct.
what happens is the fft just gives u the first window, its made to give only the non repeating part...
actually every discrete signal is a periodic in frequency domain.
so the actual fft that u obtained(which is a spike delta function),,, repeat it to get ur actual frequency domain(which is a impulse train again, repeated impulses, coz FD is periodic)
mon
    Nosheen
Nosheen
Member level 1
delta train matlab
yes, u r correct..i am having a peak at zero freq and all zeroz else where...
the problem iz that i want to see the plot of FFT of the impulse train as
--> the first peak at zero freq
--> 2nd impulse at Fs(or 1/Ts)
--> third at 2Fs(1/2Ts) and so on
i want the FFT to look like this in MATLAB... IZ IT POSSIBLE???
mondunno
plot impulses train
>> freqRepeated = repmat(freq, 1, 10);
>> stem([(0:Len*10-1)/(Len*Ts)], abs(freqRepeated))
this method just shows 10 repetetions of FFT of impulse train...
