Hi Manikandan,
Here are some of the guidelines that should be followed in High speed PCB routing
Give a lot of consideration to component placement and orientation.
• Avoid overlapping clock harmonics. Make a harmonic table for each clock.
• Clock signal loop area must be kept as small as possible. Get paranoid about clocks!
• Use multilayer boards with power & ground planes whenever possible.
• All high frequency signal traces must be on layers adjacent to a plane.
• Keep signal layers as close to the adjacent plane layer as possible (< 10 mils).
• Above 25 MHz PCB's should have two (or more) ground planes.
• When power & ground planes are on adjacent layers, the power plane should be recessed from the
edge of the ground plane by a distance equal to 20 times the spacing between the planes.
• Bury clock signals between power & ground planes whenever possible.
• Avoid slots in the ground plane. Also applies to the power plane.
• If a segmented power plane is necessary, signal traces must not be routed over the slots.
• Filter (series terminate) the output of clock drivers to slow down their rise/fall times and to reduce
ringing (typically 33 to 70 ohms).
• Place the clocks & high-speed circuitry as far away from the I/O area as possible.
• Use a minimum of two equal value decoupling capacitors on DIP packages, four on square packages.
On high frequency/high power/noisy IC's many more capacitors may be necessary.
• Consider using embedded capacitance PCB structures for decoupling on h-f boards (>50 MHz)
• Use impedance-controlled PCB layout techniques (with proper terminations) where necessary
• On impedance-controlled PCBs, do not transition the signal from one layer to another unless both
layers are referenced to the same plane.
• On non impedance-controlled PCBs, when a clock transitions from one layer to another & the layers
are referenced to different planes add a transfer via or capacitor between the planes.
• All traces whose length (in inches) is equal to or greater than the signal rise/fall time (in
nanoseconds) must have provision for a series-terminating resistor (typically 33 ohms).
• Simulate all nets whose length (in inches) is equal to or greater than the signal rise/fall time (in ns)
• Connect logic ground to the chassis (with a very low Z connection) in the I/O area. This is crucial!
• Provide for an additional ground to chassis connection at the clock/oscillator location.
• Additional ground to chassis connections may also be required.
• Daughter boards (with h-f, noisy devices and/or external cables) must be properly grounded to the
motherboard and/or chassis (do not rely on the ground pins in the connector to provide this ground).
• Provide C-M filters on all I/O lines. Group all I/O lines together in a designated I/O area of the PCB.
• Shunt capacitors used in I/O filters must have a very low impedance connection to chassis.
• Use a power entry filter on the dc power line (both C-M & D-M)
• Most products in plastic enclosures need to be provided with an additional metal reference plane.
• Consider the use of board level component shields where applicable.
• Ground all heat sinks.
Regards,
sandhya
