* AD817 SPICE Macro-model
* Description: Amplifier
* Generic Desc: High Speed, Low Power Wide Vs Op Amp
* Developed by: ARG / ADI
* Revision History: 08/10/2012 - Updated to new header style
* 1.0 (11/1992)
* Copyright 1993, 2012 by Analog Devices, Inc.
* Refer to http://www.analog.com/Analog_Root/static/techSupport/designTools/spiceModels/license/spice_general.html for License Statement. Use of this model
* indicates your acceptance with the terms and provisions in the License Statement.
* BEGIN Notes:
* Not Modeled:
* Parameters modeled include:
* END Notes
* Node assignments
* non-inverting input
* | inverting input
* | | positive supply
* | | | negative supply
* | | | | output
.SUBCKT AD817 2 1 99 50 46
* INPUT STAGE AND POLE AT 160MHZ
I1 8 50 1E-3
Q1 4 1 6 QN
Q2 5 3 7 QN
CIN 1 2 1.5PF
R1 99 4 1.188K
R2 99 5 1.188K
C1 4 5 4.187E-13
R3 6 8 1.137K
R4 7 8 1.137K
IOS 1 2 12.5E-9
EOS 3 2 POLY(1) (15,98) 0.5E-3 10
* GAIN STAGE AND DOMINANT POLE AT 8.8KHZ
EREF 98 0 POLY(2) (99,0) (50,0) 0 0.5 0.5
G1 98 9 (4,5) .8415E-3
R5 9 98 5.942E6
C2 9 98 3.045E-12
D1 9 10 DX
D2 11 9 DX
V1 99 10 1.83
V2 11 50 1.83
* COMMON MODE STAGE WITH ZERO AT 3.16KHZ
ECM 14 98 POLY(2) (1,98) (2,98) 0 0.5 0.5
R7 14 15 1E6
C4 14 15 5.036E-11
R8 15 98 1
*POLE AT 120MHZ
GP2 98 31 (9,98) 1E-6
RP2 31 98 1E6
CP2 31 98 1.326E-15
*ZERO AT 60MHZ
EZ1 32 98 (31,98) 1E6
RZ1 32 33 1E6
RZ2 33 98 1
CZ1 32 33 2.65E-15
*ZERO AT 100MHZ
EZ2 34 98 (33,98) 1E6
RZ3 34 35 1E6
RZ4 35 98 1
CZ2 34 35 1.59E-15
*POLE AT 120MHZ
GP3 98 36 (35,98) 1E-6
RP3 36 98 1E6
CP3 36 98 1.326E-15
*POLE AT 160MHZ
GP10 98 40 (36,98) 1E-6
RP10 40 98 1E6
CP10 40 98 .995E-15
* OUTPUT STAGE
RO1 99 45 16
RO2 45 50 16
G7 45 99 (99,40) 62.5E-3
G8 50 45 (40,50) 62.5E-3
G9 98 60 (45,40) 62.5E-3
D7 60 61 DX
D8 62 60 DX
V7 61 98 DC 0
V8 98 62 DC 0
GSY 99 50 (99,50) 7.692E-6
FSY 99 50 POLY(2) V7 V8 5.77E-3 1 1
D9 41 45 DX
D10 45 42 DX
V5 40 41 0.04
V6 42 40 0.04
LO 45 46 .06E-9
* MODELS USED
.MODEL DX D
.MODEL QN NPN(BF=151.52)
.ENDS
