Ninja13
Junior Member level 2
Hello everyone,
I am new on this forum and i am a new user of Cadstar. I hope someone could help me.
I would like to import a DXF (made on DraftSight) on Cadstar Design editor. The import is success full but i see 0 in front of the different item listed and i don"t why.
Here is the steps i followed:
- create my dxf in ASCII R2004-2006 version, i could use other version if needed?
-draw a simple square, select it to a new layer called boardoutline
- save it.
- Open Cadsart Design Editor
- open a new PCB Design 2 layer file
- click on file import, dxf type and pointing to the dxf file
- create a new mapping file , whatever its name
- edit map , in main tab, i have select the boardoutline layer to the dxf board layer and none to the dxf board Cutout.
- tick the transfert board and not the fix board. I have not touch to any other parameters.
- ok twice and then the report:
0 board outline imported
0 area(s) imported
0 copper item(s) imported
0 figure(s) imported
0 template(s) imported
0 text item(s) imported
0 dimension(s) imported
0 critically placed components found in dxf file
0 critically placed components added to design
0 critically placed components already in design
File C:\Users\Documents\file_ASCI_R2004_2006.dxf successfully imported
Do you have any explanation?
Thank you
- save it.
0 area(s) imported
Thank you
