Implementation of PWM on FPGA
loki3118
Junior Member level 2
Hello,
I recently switched from VHDL to Verilog to more utilize my background in programming in C++. I was given a project in which i need to implement PWM on a FPGA. I've been trying my best to do my research and look at examples of PWM that are floating around the internet. I written some code that I believe does what I would like, however Xilinx ISE compiler shot down my hopes.
If anyone could provide some feedback regarding the code that I have written it would be much appreciated. There are lots of errors with my code but at this moment I am reading up on the proper syntax of the Verilog.
Project specifications:
Xilinx FPGA Spartan-6
ISE Webpack
Switching Frequency of 5MHz (next iteration would duplicate this code to allow for 4 phases at 5MHz each)
module pwm(
    input clk,
    input write_data[31:0],
    input cs,
    input write_n,
    input addr,
    input clr_n,
    output read_data[31:0],
    output pwm_out
reg	period;
reg	counter;
wire [31:0]	pulse_width;
wire [31:0]	off;
wire [31:0] period_en;
wire [31:0] pulse_width_en;
// Define period and pulse_width registers
always @(posedge clk or negedge clr_n)
begin
	if (clr_n == 0)
		begin
			period <= 32'h // Requires a period of 0.03 nanosecond
			pulse_width <= 32'h00000000;
		end
	else
		begin
 			if (period_en)
				period <=> // Same period issue
			else
				period <= period;=""> // Same period issue
			if (pulse_width_en)
				pulse_width <= write_data[31:0];
			else
				pulse_width <= pulse_width;
		end
 	 end
// Read access for period and pulse_width registers
	if (addr == 0)
		read_data = period;
	else
		read_data = pulse_width;
//Counter
begin
	if (clr_n == 0)
		counter <= 0;
	else
	if (counter >= period - 1)    // count from 0 to (period-1)
 		counter <= 0;
	else
		counter <= counter="" +="" 1;// Is this proper syntax?
	end
// Changes output while counter is less than pulse_width
begin
	if (clr_n == 0)
		off <= 0;
	else
	if (counter >= pulse_width)
		off <= 1;
	else
	if (counter == 0)
		off <= 0;
	else
		off <= off;
end
//Enables writing to period and pulse_width registers
assign period_en = cs & !write_n & !addr;
assign pulse_width_en = cs & !write_n & addr;
// Output
assign pwm_out = !off;
endmodule
Things like: input write_data[31:0],
change to: input [31:0] write_data[31:0],
Wut? period <=> // Same period issue
Also, better not mix <= and = assignments in the same always block. Pick one and stick with it. I'd say the natural choice up there would be <=.
See: https://www.asic-world.com/tidbits/blocking.html
I followed your advice however there are problem with trying to index into arrays. I also made some other modifications to clean up the code.
module pwm (
input	clk,
input	cs,
input	wrote_n,
input	addr,
input clr_n,
output pwm_out
// signal declarations
reg	period;
reg	counter;
reg	read_data;
reg	enables;
wire [31:0]	off[31:0];
wire [31:0]	period_en[31:0];
wire [31:0]	pulse_width_en[31:0];
wire [31:0]	pulse_width[31:0];
// Define contents of period and pulse_width registers including write access for these registers
begin
if (clr_n == 0)
begin
period <= 32'h00000000;
pulse_width[31:0] <= 32'h00000000;
end
else
begin
if (period_en[31:0])
period <= 00000001;
else
period[31:0] <= period[31:0];
if (pulse_width_en[31:0])
pulse_width[31:0] <= write_data[31:0];
else
pulse_width[31:0] <= pulse_width[31:0];
end
end
// read access for period and pulse_width registers always @(addr or period or pulse_width)
if (addr == 0)
read_data <= period[31:0];
else
if
read_data <= pulse_width[31:0];
// counter which continually counts up to period
begin
if (clr_n == 0)
counter <= 0;
else
if (counter >= period - 1)// count from 0 to (period-1)
counter <= 0;
else
counter <= counter + 1;
end
// Turns output on while counter is less than pulse_width; otherwise turns output off. !off is connected to PWM output
begin
if (clr_n == 0)
off[31:0] <= 0;
else
if (counter >= pulse_width[31:0])
off[31:0] <= 1;
else
if (counter == 0)
off[31:0] <= 0;
else
off[31:0] <= off[31:0];
end
// write enable signals for writing to period and pulse_width registers
assign period_en[31:0] = cs & !write_n & !addr;
assign pulse_width_en[31:0] = cs & !write_n & addr;
// PWM output
assign pwm_out = !off[31:0];
endmodule
Oh man, crap. My bad. I accidentally forgot to erase some part.
Where you had:
You should write:
input [31:0] write_data,
And not like I accidentally wrote with [31:0] occuring two times on that line. What I wrote in the previous post would mean a 32-sized array of 32-bit words. Which was not my intent. My intent was just a single 32-bit word.
Also note that in verilog-2001 you cannot use arrays in the port declaration.
