how to implement mixer in fpga
Somebody asked the similar question in comp.arch.fpga newsgroup. Here is one reply.
Subject: Re: Sine function implementation in FPGA??
View: Complete Thread (6 articles)
Original Format
Newsgroups: comp.arch.fpga
Date: 2004-10-05 16:14:11 PST
How many bits precision do you need? How many angles, or what is the
angular resolution you need? How about the angular range if less than
+/-pi? There are several ways of obtaining the sine. For lower angular
resolution, a look up table works fine if you have the on-chip memory
available. There are also several approximations (one that I've used is
a two step linear approximation with a correction that uses two fairly
small look-ups). You can also compute the sign algorithmically using a
CORDIC rotation at the expense of more latency. If your design needs to
multiply some signal by a sine, say a mixer and local oscillator, then
CORDIC might be advantageous as it can accomplish both the sine and the
multiply in one operation. I have papers on my website on CORDIC and a
Xilinx XCELL article I wrote on using CORDIC as a mixer in a digital
radio app. For behavioral VHDL, you can use the sine and cosine
functions in ieee.math_real...those are computed using CORDIC in that
package, by the way.
SD wrote:
> Hi,
> I am trying to implement a DSP algorithm in a FPGA. My algorithm has
> sine and cosine functions in it. Can somebody help me in implementing
> sine and cosine functions in MATLAB fixed point (using fixed point
> toolbox) or VHDL.
> Thanks,
> SD
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
ray@andraka.com
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Post a follow-up to this message
