No, there is no single document that specifies what impedance all signals have to be. The ones you quote do come from the individual specifications for USB, DDR, etc. But at the same time, other signals are less tightly controlled in those same applications. For example, single ended USB signals can be between 45 and 80 ohms - so what you would use for your specific PCB design would depend on the chip manufacturer.
You have to look at the individual specifications for the type of device with which you are working, and also the chip manufacturer's data for the chipsets you are using.
