eoncu
Junior Member level 1
Hello,
I am trying to design a matching circuit that shows (1600+500j) ohm impedance from one of its port and 50 ohm impedance from the other port of it. I plan to use transistor in common collector configuration.But it seems difficult to have an impedance of such high value after 1 MHz. Has anyone designed such a matching network that uses transistors? The matching will be in the range of DC to 1 GHz.
Thnk you very much...
