Image Processing in ARM
sadeghkarimi
Newbie level 2
Newbie level 2
Hello everybody
Could you please F1 Me??!
I want to process an image in Keil using ARM Cortex M-3 (LPC1768). I want to move a window(vector) over my image and compute sth using those pixels in the Window;
The Vector is : [-1 0 1] , Means that minus last and first pixels and put it in the middle.
The compiler doesn’t allow me to access pixels. Also my image is in vector form. I need Sth like this :
For (i=0,i<1240,i++){
Pic(i)=image(i+1)-image(i-10);
Before performing such an action also I want to zero pad my image for margins.
But vector Analysis in Keil doesn’t allow me to do such an easy process.
So what( the h… ) should I do ? Please Help me?
Hello,
To help you, we need to know in which format is stored the image in memory ( RGB 565/888 or YCrCb or other), the pixel order (X->Y or Y->X) and so on.
Hello alex,
Thanks for replying.
The format is RGB 565 and camera sensor is Ov7670
Thanks in advance
Hello,
Assuming that your camera driver store the image in a unsigned short array you can use a function similar to:
void make_filtered_image( unsigned short *source_array, //pointer to source array
                 unsigned short *dest_array,     //pointer to dest array
                 unsigned short x_size,             //x size in pixel
                 unsigned short y_size)            //y size in pixel
  unsigned short x,y,s0,s1,s2;
  int r0,g0,b0,r1,g1,b1,r2,g2,b2;
  for (y=0;y<y_size;y++)	//y loop
    s0=0;s1=*source_array++;	//init s0 s1
    for (x=0;x<x_size;x++)	//x loop
      if (x<x_size)		//if no last x pixel
        s2=*source_array++;	//   get s2
      else			//else s2=0
        s2=0;
      r0=s0&0xF800;		//split RGB components
      g0=s0&0x7e0;
      b0=s0&0x1f;
      r2=s2&0xF800;
      g2=s2&0x7e0;
      b2=s2&0x1f;
      r1=r2-r0;		//apply filter -1 0 +1
      if (r1<0) r1=0;		//clip
      g1=g2-g0;		//apply filter -1 0 +1
      if (g1<0) g1=0;		//clip
      b1=b2-b0;		//apply filter -1 0 +1
      if (b1<0) b1=0;		//clip
      *dest_array++=(unsigned short)(r1|g1|b1);
      s0=s1;
      s1=s2;
[/FONT]
