Indian
Junior Member level 3
Regarding image compression i thought of an idea please reply me whether its existing or not or its useless.
The idea is i am going to divide the total image into blocks. In each and every block i will determine all the different color values present there and then i will enter the color values into a table linking with a lower symbol consisting of less no of bits then the orginal and the replace the values in the block with there corresponding sysmbols. here no loss of data so the precision of the image can be maintain, but it will fails when all the values present in the block are diff, but in most of the case it will not be so
Thanks
Thanks
