kazvah45
Newbie level 1
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 I am working on writing vhdl code for serial multiplier but am stuck on port map. I have uploaded an image for you to see what I am dealing with : [I]**broken link removed**[/I] Here is my code so far: [syntax=vhdl] library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.numeric_STD.all; entity bitserial is Port ( A_IN : in STD_LOGIC_VECTOR (7 downto 0); B_IN : in STD_LOGIC_VECTOR (7 downto 0); CLK : in STD_LOGIC; LOAD : in STD_LOGIC; P_OUT : out STD_LOGIC_VECTOR (15 downto 0); DONE : out STD_LOGIC); end bitserial; architecture Behavioral of bitserial is -------I declare some signals----------- signal weasig :std_logic; signal wepsig: std_logic; signal operand1: std_logic_vector(7 downto 0); signal operand2: std_logic_vector(7 downto 0); signal sigP: std_logic; signal sigA: std_logic_vector(7 downto 0); ------Here are my components--------- component FSM is Port ( clock1 : in STD_LOGIC; Load : in STD_LOGIC; wr_a : out STD_LOGIC; wr_p : out STD_LOGIC; done : out STD_LOGIC); end component; component Reg_A is Port ( clock1 : in STD_LOGIC; A_in : in STD_LOGIC_VECTOR (7 downto 0); we_a : in STD_LOGIC; A_out : out STD_LOGIC_VECTOR (7 downto 0)); end component; component Shift_Reg is Port ( clock1 : in STD_LOGIC; B_in : in STD_LOGIC_VECTOR (7 downto 0); we_p : in STD_LOGIC; Sum : in STD_LOGIC_VECTOR (8 downto 0); done : in STD_LOGIC; P_out : out STD_LOGIC_VECTOR (15 downto 0)); end component; component mux2x1 is Port ( in0 : in STD_LOGIC_VECTOR (7 downto 0); in1 : in STD_LOGIC_VECTOR (7 downto 0); output : out STD_LOGIC_VECTOR (7 downto 0); sel : in STD_LOGIC); end component; ------Here is where I messed up in the port map------ begin U0: FSM port map(Load => LOAD, clock1 => CLK, wr_a => weasig, wr_p => wepsig, done => ); U1: Reg_A port map(clock1 => CLK, A_in => A_IN, we_a => weasig, A_out => sigA); U2: Shift_Reg port map(clock1 => CLK, B_in => B_IN,P_out(15 downto 8) => operand1, done => donesig, we_p => wepsig, Sum => ); U3: mux2x1 port map(in1 => sigA, in0 => , sel => sigP , output => operand2); end Behavioral;
As you can see it is incomplete and there are some unconnected ports because I am confused especially with the operand1 and operand2 signal.
Any replies would be helpful.
Edit: Nevermind I figured it out sorry for disturbing you guys!
