I'm not getting the output pic24fj128ga010
rakshith
Junior Member level 2
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
#include <p24FJ128GA010.h>
#include<i2c.h>
#include<uart.h>
_CONFIG1(JTAGEN_OFF & GCP_OFF & GWRP_OFF & BKBUG_OFF & ICS_PGx2 & FWDTEN_OFF)
_CONFIG2(IESO_OFF & FCKSM_CSDCMD & OSCIOFNC_ON &  FNOSC_PRI & POSCMOD_HS)
//#define TIMEOUT 0xff                  // defines the timeout value, must not be too small
#define slave 0x0b
unsigned char isRxReceived;             // this flag will indicate if all characters has been recieved and UART is idle again
unsigned char isLoading;                // this flag will indicate if UART has recieve a single character
unsigned char nBuffOutIdx;              // this index is use to fill buffer, indicator of how many character is loaded on the buffer.. ect
char I2CBuffer[16] = "                ";// this is the buffer and limited only to 16 bytes as LCD has 16 characeter per line only
//char dummy;                               // its a dummy variable usually use when disposing the read value
unsigned char bI2CRecieve;              // its a flag used to indicate that I2C is recieving from its master
unsigned char bI2CHasStarted;           // its a flag used to indicate that I2C is done recieving from its master and I2C has detected alredy the stop bit
// Globally Defined Methods
void OutToUART();
void I2CInit();
void UARTInit();
unsigned char I2C1Send();
unsigned char I2C1Receive();
unsigned long int TIMEOUT =100;
int main()
    UARTInit();              //Initialize UART1 Module
    I2CInit();               //Initialize I2C1 Module
    bI2CRecieve = 0;         //Initialize flags and indeces
    bI2CHasStarted = 0;
    isRxReceived = 0;
    isLoading = 0;
    nBuffOutIdx = 0;
    while(1)
        if( isLoading )
        {                                   // load character receive to output buffer
            char buffer;
            unsigned long int dly =0;           // initialize delay duration local to this section
            while(!U1STAbits.TRMT);
            if( nBuffOutIdx < 16 )          // read RX regbuffer if output buffer is not yet full
                buffer = U1RXREG;
                I2CBuffer[nBuffOutIdx] = buffer;
                nBuffOutIdx++;
            else
                buffer = U1RXREG;           // discard when out of buffer range
            while (dly<205 )                    // delay 205 cycle
            dly++;
            if( (U1STAbits.RIDLE))          // is receiver idle?
                isRxReceived = 1;           // if yes, output buffer to LCD
            isLoading = 0;                  // clear is loading flag
        if( isRxReceived )
        unsigned char nIndex = 0;       // reset Global Index
            while( nIndex < nBuffOutIdx )   // if index < buffer character count, output character to LCD
                unsigned short tout = 0;
            //  U1TXREG = I2CBuffer[nIndex];// send back the character to TX buffer for transmission
                while ( !U1STAbits.TRMT && tout < TIMEOUT)tout++;   // stay here while character at shift register is not yet transmitted
                nIndex++;                   // next character
            I2C1Send( );                    // send recived data from buffer to I2C
            isRxReceived = 0;               // clear receive flag
            nBuffOutIdx = 0;            // reset output buffer index to 0
           // I2C1CONbits.RSEN=1;        //repeated start condition
            //I2C1CONbits.RCEN=1;        // receive enable
        I2C1Receive();
    /*  if( bI2CRecieve )
            if( !I2C1STATbits.D_A && !I2C1STATbits.R_W)
                dummy = I2C1RCV;                // address recieved
                nBuffOutIdx = 0;                // clear buffer index when slave address is recived
                I2C1CONbits.SCLREL = 1;
                bI2CHasStarted = 1;
            if( I2C1STATbits.D_A && !I2C1STATbits.R_W)
                I2CBuffer[nBuffOutIdx] = I2C1RCV & 0xff;    // data recieved then stored to buffer
                I2C1CONbits.SCLREL = 1;         // release the clock
                nBuffOutIdx++;                  // increment buffer index
            bI2CRecieve = 0;                    // clear the section flag
        if( bI2CHasStarted && I2C1STATbits.P )
             bI2CHasStarted = 0;                // clear the section flag
             OutToUART();                       // send to hyperterminal by UART TX
return 0;*/
void OutToUART()
    unsigned char i = 0;
    while( i < nBuffOutIdx )
    {   unsigned tout = 0;
        U1TXREG = I2CBuffer[i];// send back the character to TX buffer for transmission
        i++;
    unsigned char I2C1Send( )
            unsigned char len = 0;
            unsigned char to = 0;
            I2C1CONbits.SEN = 1;        // Set start bit
            while( I2C1STATbits.S && (to < TIMEOUT) )to++;  // wait for start bit flag to set
            to = 0;
            I2C1TRN = (slave << 1) & 0xFE;              // send (slave + write bit )
            while ( I2C1STATbits.TRSTAT && (to < TIMEOUT))to++; // wait for Transmit bit to be cleared
            to = 0;
            if( I2C1STATbits.ACKSTAT )
        //  I2C1CONbits.PEN = 1;        // Set stop bit
            return 1;                   // ret 1 if NAK
            while ( len < nBuffOutIdx )
                I2C1TRN = I2CBuffer[len];               // send data
                while ( I2C1STATbits.TRSTAT && (to < TIMEOUT) )to++;    // wait for Transmit bit to be cleared
                to = 0;
                len++;
            return 0;
    I2C1TRN = (slave << 1) & 0xFF;              // send (slave + write bit )
    if(I2C1STATbits.RBF)
       return 1;
   //   I2C1CONbits.SCLREL = 1;         // release the clock
OutToUART();
void __attribute__((interrupt, shadow, no_auto_psv)) _SI2C1Interrupt()
    bI2CRecieve = 1;
    IFS1bits.SI2C1IF = 0;                   // manually cleared SI2C1 Interrupt flag
void I2CInit()
    //I2C1MSK = 0x00;           // set this controller's device address
    I2C1CONbits.I2CEN = 1;      // enable I2C module
    I2C1CONbits.I2CSIDL = 0;    // Continue module operation in Idle mode
    //I2C1CONbits.SCLREL = ;
    I2C1CONbits.IPMIEN = 0;     // IPMI mode disabled
    I2C1CONbits.A10M = 0;       // I2C1ADD is a 7-bit slave address
    I2C1CONbits.DISSLW = 0;     // for 400 kHz up enable slew rate
    I2C1CONbits.SMEN = 1;       // signal conditioning
    I2C1CONbits.GCEN = 0;       // for slave mode only
    I2C1CONbits.STREN = 1;      // Enable software or receive clock stretching, therefore clock must be release by slave when done on loading data to sync clock
    I2C1BRG = 31;               // use 1MHz SCL frequency but apparently, its frequency is 666 kHz
    IEC1bits.SI2C1IE = 1;       // enable Slave I2C1 interrupt
    IEC1bits.MI2C1IE = 1;       // enable Master I2C1 interrupt
void UARTInit()
    U1BRG = 25;                 // 9600
    U1MODEbits.UARTEN = 1;      // UART1 is Enabled
    U1MODEbits.USIDL = 0;       // Continue operation at Idlestate
    U1MODEbits.IREN = 0;        // IrDA En/Decoder is disabled
    U1MODEbits.RTSMD = 0;       // flow control mode
    //U1MODEbits.UEN = 0b10;        // UTX, RTX, U1CTS, U1RTS are enable and on use.
    U1MODEbits.WAKE = 1;        // Wake-up on start bit is enabled
    U1MODEbits.LPBACK = 0;      // Loop-back is disabled
    U1MODEbits.ABAUD = 0;       // auto baud is disabled
    U1MODEbits.RXINV = 0;       // No RX inversion
    U1MODEbits.BRGH = 0;        // low boud rate
    U1MODEbits.PDSEL = 0b00;    // 8bit no parity
    U1MODEbits.STSEL = 0;       // one stop bit
    U1STAbits.UTXISEL1 = 0b00;
    //U1STAbits.TXINV = 0;      // cant compile TXINV.. why???
    U1STA &= 0xDFFF;            // clear TXINV by bit masking
    U1STAbits.UTXBRK = 0;       // sync break tx is disabled
    U1STAbits.UTXEN = 1;        //transmit  is enabled
    U1STAbits.URXISEL = 0b00;   // interrupt flag bit is set when RXBUF is filled whith 1 character
    U1STAbits.ADDEN = 0;        // address detect mode is disabled
    IFS0bits.U1RXIF = 0;        // clear interrupt flag of rx
    IEC0bits.U1RXIE = 1;        // enable rx recieved data interrupt
    IFS0bits.U1TXIF = 0;        // clear interrupt flag of rx
    IEC0bits.U1TXIE = 1;        // enable rx recieved data interrupt
void __attribute__((interrupt, shadow, no_auto_psv)) _U1RXInterrupt()
    IFS0bits.U1RXIF = 0;                    // manually cleared U1RX Interrupt flag
    isLoading = 1;                          // signal main to store character recieve to buffer
void __attribute__((interrupt, shadow, no_auto_psv)) _U1TXInterrupt()
    IFS0bits.U1TXIF = 0;                    // manually cleared U1RX Interrupt flag
void __attribute__((interrupt, shadow, no_auto_psv)) _MI2C1Interrupt()
    IFS1bits.MI2C1IF = 0;                   // manually cleared MI2C1 Interrupt flag
  • New Text Document.txt
for a start you have missmatched {} in main(), e.g. line 127 to 130
return 0;*/
should be
return 0;
also you have a ; on the end of line 191 which should not be there
Horace 1 :
I made these changes , in spite i'm not getting the output..!
Can you zip and upload the proteus .dsn file?
In your code
int main()
    bI2CHasStarted = 0;
    isRxReceived = 0;
    isLoading = 0;
    nBuffOutIdx = 0;
    while(1)
        if( isLoading )
 isLoading = 0;
then how can
  if( isLoading )
work?
Same with
 isRxReceived = 0;
 if( isRxReceived )
what is line 210 for? remove it?
you appear to have a spare } at the end of the code
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
#define slave 0x0b
void OutToUART();
void I2CInit();
void UARTInit();
int main()
    bI2CHasStarted = 0;
    isRxReceived = 0;
    isLoading = 0;
    nBuffOutIdx = 0;
    while(1)
        if( isLoading )
            char buffer;
                buffer = U1RXREG;
                nBuffOutIdx++;
            else
            dly++;
        I2C1Send( );// send recived data from buffer to I2C
    I2C1Receive();
        if( isRxReceived )
            OutToUART( );
return(0);
            to = 0;
            to = 0;
            if( !I2C1STATbits.ACKSTAT )
                to = 0;
                len++;
        //I2C1CONbits.PEN = 1;      // Set stop bit
            return 0;
    I2CBuffer[nBuffOutIdx] = I2C1RCV & 0xFF;    // data recieved then stored to buffer
void OutToUART( )
        i++;
    bI2CRecieve = 1;
void I2CInit( )
    I2C1CONbits.SCLREL =1 ;
void UARTInit( )
    U1BRG =25;                  // 9600
    //U1STAbits.TXINV = 0;      // cant compile TXINV..why??
    //U1STAbits.URXISEL = 0b00; // interrupt flag bit is set when RXBUF is filled whith 1 character
horace 1 :
I'v made few changes including things u said...!
I'm not able to get any output..!
internetuser2k12 :
This is the file which i'm using..!
I'v deleted LCD part in this..! n only uart n i2c r configured..
  • CE363 - Hyperterminal - UART - I2C - LCD.zip
Which Compiler are you using? Can you upload the Schematic? Where are the TRIS Commands?
internetuser2k12 :
I'm using c30 compiler in MPLAB IDE v8.60.
I using docklight to send n receive commands.
Can you upload the schematic, so that it can be simulated in proteus?
internetuser2k12 :
Actually i do't require TRIS commands for this program know??
I really do't know what s meant by SCHEMATIC" - whats that???
I don't know exactly. But can you try TRIS. Schematic = Circuit diagram.
internetuser2k12 :
As i know TRIS s for input n output ports ,i'm using UART n I@C.!
anyways i'l hv a try eve on that.
I'm usings PIC24FJ128GA010 mounted on Explrer 16 board,n i've made connection thru soldering UART n I2C found by data specification sheet of pic24fj128ga010.
do u want a photo of the things which i'm or the data sheet's of all this which contains schematic .
internetuser2k12 :
r these fine..?
No. It doesn't work. I want to know to which ports your lcd and other things are connected. Can you draw the schematic in proteus? OK I got the Explorer 16 in proteus. Can you send the full source code which compiles so that I can debug in proteus and see?
Have you cannected pull up resistors to the SCL and SDA lines as mentioned here http://www.robot-electronics.co.uk/acatalog/I2C_Tutorial.html
internetuser2k12 :
any reason why you are using UART1 rather than UART2 which is connected to P1 the 9 pin D type connector of the explorer 16 (next to the power connector)?
this code prints "hello world" to UART2 at 9600 baud correctly (I have changed UART1 code to UART2 and added two functions)
#define slave 0x0b
void OutToUART();
void I2CInit();
void UARTInit();
void __attribute__((interrupt, shadow, no_auto_psv)) _U2RXInterrupt()
	IFS1bits.U2RXIF = 0;					// manually cleared U2RX Interrupt flag
void __attribute__((interrupt, shadow, no_auto_psv)) _U2TXInterrupt()
	IFS1bits.U2TXIF = 0;					// manually cleared U2RX Interrupt flag
int main()
	UART2PrintString("hello world\r\n");
	bI2CHasStarted = 0;
	isRxReceived = 0;
	isLoading = 0;
	nBuffOutIdx = 0;
	while(1)
		if( isLoading )
			char buffer;
			while(!U2STAbits.TRMT);
				buffer = U2RXREG;
				nBuffOutIdx++;
			else
				buffer = U2RXREG;			// discard when out of buffer range
			dly++;
			if( (U2STAbits.RIDLE))			// is receiver idle?
	I2C1Receive();
		if( isRxReceived )
            OutToUART( );
return(0);
			to = 0;
			to = 0;
				to = 0;
				len++;
			return 0;
void OutToUART( )
		U2TXREG = I2CBuffer[i];// send back the character to TX buffer for transmission
		while ( !U2STAbits.TRMT && tout < TIMEOUT)tout++;	// stay here while character at shift register is not yet transmitted
		i++;
	bI2CRecieve = 1;
void I2CInit( )
void UARTInit( )
	U2BRG =25;					// 9600
	U2MODEbits.UARTEN = 1;		// UART1 is Enabled
	U2MODEbits.USIDL = 0;		// Continue operation at Idlestate
	U2MODEbits.IREN = 0;		// IrDA En/Decoder is disabled
	U2MODEbits.RTSMD = 0; 		// flow control mode
	//U2MODEbits.UEN = 0b10;		// UTX, RTX, U2CTS, U2RTS are enable and on use.
	U2MODEbits.WAKE = 1;		// Wake-up on start bit is enabled
	U2MODEbits.LPBACK = 0;		// Loop-back is disabled
	U2MODEbits.ABAUD = 0;		// auto baud is disabled
	U2MODEbits.RXINV = 0;		// No RX inversion
	U2MODEbits.BRGH = 0;		// low boud rate
	U2MODEbits.PDSEL = 0b00; 	// 8bit no parity
	U2MODEbits.STSEL = 0;		// one stop bit
	U2STAbits.UTXISEL1 = 0b00;
	//U2STAbits.TXINV = 0; 		// cant compile TXINV..why??
	U2STA &= 0xDFFF;			// clear TXINV by bit masking
	U2STAbits.UTXBRK = 0;		// sync break tx is disabled
	U2STAbits.UTXEN = 1;		//transmit  is enabled
	//U2STAbits.URXISEL = 0b00;	// interrupt flag bit is set when RXBUF is filled whith 1 character
	U2STAbits.ADDEN = 0;		// address detect mode is disabled
	IFS1bits.U2RXIF = 0;		// clear interrupt flag of rx
	IEC1bits.U2RXIE = 1;		// enable rx recieved data interrupt
// Function:UART PutChar - This routine writes a character to the transmit FIFO
void UART2PutChar(const char ch )
    while(U2STAbits.TRMT == 0);	// wait for transmit ready
    U2TXREG = ch;				// transmit character
//Function:UART PrintString - prints a string of characters to the UART.
void UART2PrintString(const char *str )
    char c;
    while( (c = *str++) )
       UART2PutChar(c);
now you know that UART2 works you can try UART1 and then the I2C
internetuser2k12 :
I'v given u a zip file above kno. that include everything..
The source file supporting file everything..
horace 1 :
i'm not able to use UART2 cuz, that pin is not working properly here..
even i did this this for UART2,i was failed . so i changed all the UART2 to UART1 the it worked..
So,i'm not using UART2. But UART1 s fine ..
internetuser2k12 :
yes, i'v .. connected pull up registers as u said..!
but still i'm in d same stage.
The code Compiled and I am getting the output shown in image.
In the code
UART1 is defined but you are using UART2. Isn't it? Can you change the code according to UART2? Or is it UART2 enabled?
horace 1:
i got the output as u said whn i changed the UART2 to UART1..
So, UART2 in our board is't working..!
I'm good with UART1..
What to do next..!.?
i do't understand anything..!:(
