eemkutay said:Hi, Friends
I have been using ICD2 with PIC16F876A and It's been working for PIC16 and PIC18 series perfectly. I also have a few PIC24FJ32GA002 but my ICD2 is not supported this series because of 3V3. Some of friends on the net say, "We can program with ICD2" but I dont know How?
Please, Can you give me a PIC24F series programmer link?
Advance in thx.
mjane said:eemkutay said:Hi, Friends
Advance in thx.
Hi.. you may try Hi-tech Software.. ANSI-C Compiler.. =)
picnoobie said:try this I used it Pic24H and now. dsPic33F.
you only need the small pcb which is the level translator,
I got the info from one of the threads here.
good luck!
good luck!
picnoobie said:VCC_T is the from the target device which if you use this for Pic24/dsPic33 would
be 3.3v, VCC is the usual 5v. You have to uncheck "Power Target from ICD" in Mplab
if you use this circuit.
So the VCC_T is a voltage (3.3V) that I must supply externally (from the target), right?
