Atmel ASF library has the driver for ili9325 controller, but I'm not sure if you'll be able to use it with Mega series. At least you can run Atmel Studio, there are example projects for this lcd controller (for atmel boards with this controller) with the source code that you can use in your projects. You can review and edit it to implement your own code.
In any case, start with the datasheet, find out about initialization procedure and basic commands.
I recommend you to take more suitable microcontroller. To work with API like emWin you will need at least 50k free RAM, FSMC and DMA to get reasonable refrash rate.
Thanks for replay.
But, this screen work with Arduino uno board. So, I think it will work with atmega32.
