If modulation index is a floating point number, how do I represent in FPGA?
keerthna
Member level 1
Member level 1
If modulation index is a floating point number, how do i represent in fpga?
I am designing a pwm module and i want to have a 4-bit input which is the modulation index and based on which the output of the sine wave changes.
For example
module lut(clk,mi,sineout);
input clk;
output sineout;
reg [3:0]mi;
since 2^4=16, i will use another signal so as to have a step size of 1/16 and this is multiplied with mi and that becomes the modulation index.
but this is a floating point number. how do i give this to the fpga?
Re: If modulation index is a floating point number, how do i represent in fpga?
If numbers are known, I suggest you create a map inside the FPGA and use indexes to point at maps. In general, FPGAs aren't friendly to floating numbers, you need to avoid them at all costs. You can find floating cores in IPCore of your FPGA IDE (Xilinx, Altera and Lattice have them), but I'd rather avoid it altogether...
