slimbobaggins
Newbie level 6
Not sure if this belongs here or in the RF section.
Looking for a little advice from Analog/ RF Engineers:
My IF coming out of my circuit is 1MHz, and I'm using approximately the following amplifier circuit to amplify it:
It's taken from this paper:
http://www.thegleam.com/ke5fx/norton/lankford.pdf
Anyhow, my transistor is a MMBT2222A (surface mount version of 2N2222A), my transformer ratio is 1:11:4, and is wound on an Amidon Multi-aperture core BN-73-2402. It gives me about 11.5 dB of gain that is fairly linear (+/- 0.1 dB) from -80 to -10 dBm input.
Above -10 dBm it starts to roll off, but not terribly, gain at +10 dBm is 3.72 dB.
My question is, what do you think my limiting factor is that's causing my gain to roll off? Am I saturating my core, or am I hitting the upper limit of my transistor? I can probably dig up some bigger cores to test with, if it's my core that's holding me back. My transistor selection is kinda limited atm, and honestly I tried the circuit with a transistor that was supposed to be much "nicer," and it didn't work as well as this does.
I should mention, my supply voltage is 12V, not 9V like in the paper. I should probably re-bias the transistor, but it worked well as-is so I didnt screw with it. Supply current is set to 24mA via the pot... Seemed to like it the best.
