Jul 19, 2005 #1 H hebu Full Member level 4 Joined Nov 15, 2004 Messages 194 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,296 Activity points 1,816 modelling fully differential op amp Where I can get the ideal differential opamp in candence? only i can get is single ended output. Or may I use two opamp to make a differential output?
Jul 19, 2005 #2 C ccw27 Full Member level 5 Joined Oct 13, 2004 Messages 267 Helped 14 Reputation 28 Reaction score 6 Trophy points 1,298 Activity points 2,558 modelling op amp fullydifferential Just use VCVS from analoglib. You can also add resistors and capacitors to emulate the pole position
Jul 19, 2005 #3 H hebu Full Member level 4 Joined Nov 15, 2004 Messages 194 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,296 Activity points 1,816 ideal differential opamp model Ya, this is a good idea, this can model the pole location and ft and dc gain. But, how to emulate the slew rate?
Jul 24, 2005 #4 Y yeewong_su Advanced Member level 4 Joined Oct 12, 2004 Messages 119 Helped 5 Reputation 10 Reaction score 3 Trophy points 1,298 Activity points 803 behavior modelling op amp cadence You can using the behavior model to gen the ideal opamp
Jul 24, 2005 #5 U uncle_urfi Full Member level 2 Joined Mar 15, 2004 Messages 146 Helped 10 Reputation 20 Reaction score 6 Trophy points 1,298 Activity points 2,004 ideal diff opamp In the ahdlLib, there is an opamp that is verilog-A based. This already has built-in parameters for gain, input resistance etc.
