djnik1362
Full Member level 2
hi
I have a 8-bit data BUS that connect several Buffers and Latches
to an AVR microcontrller.
I want to connect FPGA to BUS so i can communicate with FPGA .
I decide to use a 8-bit latch to feed data BUS to FPGA as input and
a 8-bit buffer to get data from FPGA and send to data BUS.
I could use a "inout" structure in FPGA but i prefer using above structure.
Suppose i have 5 software block in FPGA that have an 8-bit output that
must fed to BUS. I connect A15-A13 address BUS to FPGA so i can choose
8 block from FPGA .
I use a 8x1 8-bit MUX in FPGA that with A15-A13 signals and RD signal choose
blocks output to connect to BUS.
I decide to create 3 software blocks that have 8-bit inputs from Data BUS.
My idea is to use a DEMUX at FPGA and 3 8-bit D-FF for each block that
with "posedge" of WR signal latch-up data BUS to proper D-FF.
I write my code in Verilog and simulate this structure with Xilin ISE 9.1 and
it work correctly.
I need your ideas that if this configuration works in practice .
Thanks for your support.
8 block from FPGA .
it work correctly.
