ICD2 Parallel Slave Port com / USB/ new design?
Alu-Spray
Newbie level 2
Newbie level 2
usb to parallel slave port
Hello
I plan to redesign the ICD2 and to replace the cypress chip. Actually I do not know exactly how the communication works.
I hope I can find some people who like to work together, finding a better solution.
My somple thought is, that the serial communication must be similar to the parralel one.
Maybe there is another suitable USB Device Chip e.g. FTDI245(I know it is a passive one, uC has to be active, doesnt work here), the Printer Port with a special driver,...
Well, I woult like to collect some Information about it here.
Sebastian
P.S. Especially the function of RB0, how does it work?
Must be a Parallel slave port communication with Handschake, or something like that.
why do you want to change the cypress part?
I believe that the MPLAB IDE have the driver specifically for the cypress, chnging to a new design might result to complcation in usb interface of the ICD.
why chnge?
abb
Hello
I think all it needs a Com Driver. If it works via RS 232, it should also work with a virtual com Port via USB or Prallel communication.
The version with a FTDI Chip (to Rs232) works, but the problem is the low RS232 Bitrate. So it needs a Chip that can handle the parallel communication of the ICD2.
First I try to collect some Information about that communication, and people helping to solve that Problem. Then, I'm sure, the solution is not that compicated it may seems.
A FTDI245 with a small device(PIC,..) working to gether to get an active Bus communication, could be a solution.
Sebastian
Added after 17 minutes:
P.S.
The problem with the cypress device is the availability.
you cab look at patrick touzet icd2 implementation
at :
it uses a cypress chip , but with parallel usb design and is really fast enought compared to the rs232/usb converters.
the cypress chip he uses is available at radiospares for some 20 euros.
