sophiefans
Member level 3
hello everybody,
There are some nets which cause lots of false violation. So i just want to ignore routing on these nets Or ignore DRC check on these nets. You know with these false violation the speed will be slow and slow. Do you know the setting?
I mean when you want to route a net group, you can use "route_zrt_group". But when you do not want a net Group be routed, how to set?
Thanks
Added after 1 hours 50 minutes:
I have a method that just get all the nets , and remove the nets which i don't want route from the total nets. Then run the net group left.
It's one method, do you have other way to do this thing?
Thanks
