IC610 installation error on CentOS5.2
kumarghz
Member level 5
Penang, malaysia
.lib error in ic610 installation
Dear Friends,
I'm getting such error when i try to install Installscape.
I also typed the uncompress command as this 'ln -s/usr/bin/gunzip /bin/uncompress'
The error is as below;
Starting up InstallScape in GUI mode
DISPLAY environment variable is set to :0.0
If you do not see the InstallScape console
window or the it seems to be hanging then kill this
process.
Set your DISPLAY environment variable to a proper
value and manually start InstallScape by typing:
/home/eda/installscape/iscape/bin/iscape.sh /home/bagside/edascr/ic610/CDROM1:::/home/eda/ic610
Initializing InstallScape using JVM at /home/eda/installscape/iscape/runtime/LNX86/bin/java. This might take some time...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/eda/installscape/iscape/runtime/LNX86/lib/i386/libawt.so: libXp.so.6: cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1586)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1503)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:834)
at sun.security.action.LoadLibraryAction.run(LoadLibraryAction.java:50)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Toolkit.loadLibraries(Toolkit.java:1437)
at java.awt.Toolkit.<clinit>(Toolkit.java:1458)
at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:70)
[root@bagvapp CDROM1]#
please guide me how to solve this problem.
thanks alot.
regards,
Kumar
kumarghz
Member level 5
Penang, malaysia
Hi All,
I have solved this problem. The solution is, need to install libXP
by command 'yum install libXP'. thanks.
However I have another error after full installation when I want to start the cadence.
To start cadence I have typed command as below;
icfb&
but this is the error was given,
Resource id: 0x2a00011
Qt Warning: X Error: BadWindow (invalid Window parameter) 3
Major opcode: 18 (X_ChangeProperty)
Major opcode: 2 (X_ChangeWindowAttributes)
Any Idea?
thanks.
regards,
Kumar
ed2000
Member level 3
1. some errors like:
Major opcode: 8 (X_MapWindow)
Resource id: 0x3600011
\e Display :0.0 Error "BadMatch (invalid parameter attributes)"
\e request 1 error 8 serial 1437
to solve this problem, add these line to the /etc/X11/xorg.conf
Section "Extensions"
Option "Composite" "Disable"
EndSection
