Ubuntu9.04, kernel 2.6-28-11-gerenic, when i try to lauch dfII using icfb command, there's error detected, saying
/EDA/IC5141/tools/dfII/bin/icfb.exe: relocation error: /EDA/IC5141/tools/dfII/bin/icfb.exe: symbol errno, version GLIBC_2.0 not defined in file libc.so.6 with link time reference
In fact, I did many search for this problem but with no luck, the issue still not fixed...I've tried added export LD_ASSUME_KERNEL=2.4.1 or export LD_LIBRARY_PATH=/lib/i686 to the .bashre and source it, problem now became:
/bin/sh: error while loading shared libraries: libc.so.6: cannot open shared object file: No such file or directory
Is there a possibility that IC5141 can work on Ubuntu9.04? I heard one member of this forum make it work on 10.04...
Hope somebody can give help one this!
Thanks!
i have succedded in installing IC5141 on RHEL 5.1 and scientific linux 5.1 from the original installation media. no tar ball makeing and no modification of install script.
**broken link removed** | **broken link removed**
