IC burned on the photo?
brunofunchas
Full Member level 3
Full Member level 3
Portugal
Hello!
I came across this IC on an ECU and I think it is burned, because of the mark on it's body. Do you agree?
Can anyone indicate me a equivalente IC to this one: Siemens B58290.
Thanks
Difficult to tell in a photograph, if the mark is slightly raised it is probably burned.
You probably not find a substitute, in an ECU the parts are usually custom made or are generic parts specially programmed to perform a specific job. You could try contacting the ECU manufacturer but I doubt you will find anything using the part number.
Brian.
  • TLE4226G.pdf
Hello!
Thanks for the datasheet. Can I find a supplier in Europe? So that I can have the part in Portugal next week? All the suppliers that I came across where outside EU and with large delivery times.
Any supplier sugestion?
Thanks
