I2C bus - 1.2us glitch is it correct or not?
EDA_hg81
Advanced Member level 2
glitch + i2c
I am using I2C bus to write data to EEPROM based on FPGA. I am running I2C at 100K HZ
During every acknowledge period, I found a single 1.2us glitch.
Are they correct or not?
Thanks.
i2c glitch
During SCL=0, it would be allowed.
    EDA_hg81
Re: I2C bus and glitch
Thank you FVM.
Is this glitch is from EEPROM ?
I am wondering if the I/O enable function of FPGA make glitch happen ?
Can we avoid this?
Thanks.
I2C bus and glitch
As a basic question: Is the communication logical correct according to the I2C standard? I can't see this from your post.
You are also able to see, which side is sending the glitch. Usually the SDA output low leves are different by a small amount. If not, you can connect a small series resistor to one output.
    EDA_hg81
