I want to get an infinite cilynder in Z
sandruska
Junior Member level 3
hy:
I want to get a infinite cylinder in z axis. Is this possible with HFSS?. I have used condition layered impedance in the extreme of the cylinder. I have used master-slave boundary condition and the result in the both cases is the same: I get a correct result in the form (more or less) but the nivel of dB's is incorrect.
some idea about this?
why dont you use periodic boundary condition along the axes of the cylinder? Maybe this may help
what do you want exactly simulate?
Rugby
Are your looking for eigenmode or driven solution?
I have tested that the periodic boundary condition along the axes of the cylinder is wrong !
I dont think you can simulate an infinte cylinder with HFSS because this program simulates maxwell's equations in a FINITE part of the space.............obviusly you cant enclose an infinite cylander in a Finite part of space.
hi
you can simulate length of this cylinder approximately greater than 5 order of simulation wavelenth.
this site has an example of simulating scattering of infinite cylinders
