I m using a DDS (Xilinx block) and i am gettin a sine wave with sample period of 0.001
i have made the phase increment option in block parameter as register and im getting two new ports 'data' and 'we'
... so now i need to know how should i get a phase increment of pi radians ...what should be the input data type to the 'data'pin of DDS?
Xilinx provides at least two different DDS cores. Which one are you using?
The DATA phase input values range from 0 to almost 2*pi radians. For example, if your DATA is 16 bits wide, then values from 0 to 65536 represent 0 to 2*pi radians. You would input 32768 to get pi radians.
