I want cicuit diagram for obtaining 230 v using solar energy...
:-D Hello there,
I just wanted to use solar energy to run a 250 watt 230v ac motor.
and i want to know that can i use a UPS for this...because the UPS has 12v DC to 230v AC inverter, so that i can replace the battery with solar energy for 12 v DC i/p to the ups....
:roll:can i do this.... plz give me suggestions and schematics if possible..
yes you can but VA rating of ups should be higher and you can't remove battery during operation
you can calculate your panel size that is around 300 W
battery size depends upon run time of motor
you need charge controller
autonomous day or hrs
cheers
