I search a "IC search engine" :-)
maluedo
Newbie level 6
Newbie level 6
How subject, there's a IC search engine for know which componenet is, trough the serial printed over?
Thanks
Maluedo
Try this :
h**p://***.epanorama.net/searchlinks.html
h**p://***.embeddedlinks.com/chipdir/
hi,
try chip*center.c*om.
bye
curgan
Personally I prefer **broken link removed**
h**p://w*w.icmaster.com/
My favorite:
<font size=-1>[ This Message was edited by: brankob on 2002-03-16 17:00 ]</font>
xxx.partminer.com
pool_77
here are few links:
**broken link removed** Datasheets Transistors
**broken link removed** Datasheets SCR/DIAC/TRIAC/UJT
**broken link removed** Datasheets J-FET
**broken link removed** Datasheets Diodes
**broken link removed** Datasheets Linear ICs
**broken link removed** Datasheets digital ICs
http://www.aufzu.de/semi/ Aufzu Semi
**broken link removed** IC-ID
**broken link removed** Manufacturer Logo
**broken link removed** Display Electronics - Europes's largest surplus stockist - Millions of
bargains - On Line NOW.
http://electronicsworld.tripod.com/ Electronic circuit diagrams, tutorials, hobby & do-it-yourself
homepage.
**broken link removed** register with a proper email address
http://www.chipcentre.com register with a proper email address
http://www.datasheetlocator.com
**broken link removed** good place for datasheets
http://www.business.conrad.de
http://www.commlinx.com.au/crosswords.htm crossword competition to win electronic
components. also http://www.commlinx.com.au/schematics.htm database of links to electronics
schematics on the web
http://www.segor.de but they charge a lot for shipping (even inside Germany)...
http://www.glyn.de (Mitsubishi, Fujitsu, Toshiba)
http://www.phytec.de (Infineon, Philips)
http://www.reichelt.de (all kind of 8051's, M16C, 68xx, ST6 and Z80's)
http://www.sander-electronic.de
**broken link removed** Direct download various analog/digital PDF Datasheets.
http://www.jmb-electronique.com Vente de composants électroniques pour l'amateur et
l'industrie
http://www.kessler-electronic.de/
**broken link removed** Accès Datasheets composants
courants
**broken link removed** Echange de composants Quantités et références
exactes disponibles.
http://www.relaycenter.com/ Cross reference pour les relais électro-mécaniques
**broken link removed** Basic knowledge of electonic parts
**broken link removed** Semiconductors Datasheets on the Web
**broken link removed** ICINFO
http://www.promelec.ru/pdftop.html Base de datasheet PDF
**broken link removed** voici une adresse intéressante remplie de datasheet de semi-conducteur
au format pdf, classé par ordre alphabétique.
http://personal.redestb.es/castillo/ Todo Electrónica: página principal
http://www.partsvault.com/ Electronic component search engine. Search for electronic
components now!
http://www.aufzu.de/semi/ aufzu Halbleiter-Ecke
**broken link removed** Anyone looking far a valuable competitive cross-reference
tool should visit **broken link removed** this site also creates a custom xref for
component manufacturers as well; email: sales@electronicdirectory.com (Phillip Paul)
http://www.comunidadelectronicos.com/sitios.htm#Componentes Information for Components
**broken link removed** Brochage des principaux
transistors
http://www.nteinc.com/ There were a couple of companies in the US that repackage
semiconductors
and sell them through distributors as universal replacement repair parts.
One of these is NTE. (http://www.nteinc.com). (Another, ECG, was part of
the Philips North American consumer electronics division (TVs and stuff),
but I read that they recently sold that to NTE). Another line of parts
is from the north american division of Thomson.
Rather than sell the parts under their original number, they have them
labeled with a part number of their own. Often, a number of OEM parts
could use the same replacment part. (Transistors, and a lot of the
japanese linear ICs often have many equivalent parts). As a part of
their operation, they publish replacement guides with lookup tables that
give their part number for the original.
There used to be several of these companies, each with their own set
of parts with different numbers. (NTE decided to copy ECG and use the
same basic numbers). Now there a just a couple, NTE and Thomson with
their SK line of parts.
The replacment guide catalog comes in useful where, if you know that
two different parts have the same function, you can look up both in the
replacement guide catalog and see if they are replaced by the same
'universal replacment' part. (The replacment guide is also on the
web, and as a PC program with a database lookup).
If you can find the original part, there's not much advantage to buying
these parts, as they go through a couple more middlemen and therefore
cost many times what you'd have to pay at a distributor that sells a
semiconductor manufacturers products. But in many cases, you can't get
the part because they don't sell it here, or it's obselete. They're also
the only semiconductors that a small local electronics distributor will
sell, as the big semiconductor companies won't do business with them
**broken link removed** Chipbook
**broken link removed** PITT's privater werbefreier Electronics- Second- Elektronik- bauteile-
Flohmarkt! IC's, Halbleiter und Passiv...
**broken link removed** Service Programmation de composants programmables
http://www.datasheetlocator.com/fr/
**broken link removed** IC Database with information about more
than 98.000 semiconductors.
**broken link removed** Japanese equivalent JFET
**broken link removed** Replacement parts for different ICs can be
found on this Site.
http://www.elv.de Kits ELV
**broken link removed** Où obtenir des datasheets et autres
informations...
**broken link removed** Source of datasheets
**broken link removed** PIC
**broken link removed** Componenti elettronici PIC
**broken link removed** Catalogue en image - Composants électroniques
Industrial Capacitors Wrexham Ltd., Miners Road, Llay Industrial Estate, Llay, rexham, LL12
0PJ Tel: +44 (0) 1978 853805 Fax: +44 (0) 1978 853785 http://www.icwltd.co.uk email:
sales@icwltd.co.uk They specialise in custom capacitors
**broken link removed** Fabricants
**broken link removed** Index Fabricants
**broken link removed** Constructeurs de composants passifs - Base de
liens
http://www.electronicsdir.com/ Searchable distributor database, datasheet search engine, many
useful links and a section to post your stock requirements can be found.
**broken link removed** Manufacturers of IC and their logos
http://www.xs4all.nl/~ganswijk/chipdir/soviet/chips.htm Equivalences circuits Russes
http://www.chipinfo.ru/literature/ CHIPINFO
http://www.fistells.com/ FISTELL'S Micro Electronics Parts
http://tcccorp.free.fr/composant Liste de composants électroniques à vendre
**broken link removed** Liste de lots de composants à vendre
http://www.ag-electronique.fr/ AG ELECTRONIQUE 51 cours de la LIBERTE 69003
LYON tel : 04 78 62 94 34 catalogue general 25F
http://www.alltronics.com/ Alltronics
http://www.greenchip.cc/ Greenchip
http://www.micronica.com.au/~micronica/pricelist/chips.htm Micronica
http://www.prelcoparts.com/prelco_001.htm PRELCO Electronics Corp.
**broken link removed** Audio-Video-Technik / IC Database
http://www.halfin.com/ tubes électroniques anciens
http://www.powercomponents.nl/ Electronic components & spare parts
http://www.donberg.ie/search.html DONBERG Electronics , Audio, video spares
http://us-electronics.com/ U.S. Electronics Inc. specializes in providing high quality electronic
components at the lowest cost.
http://www.moyerelectronics.com on-line transistor cross-reference
**broken link removed** Glyn GmbH & Co. KG (Distributor für aktive, passive und
elektromechanische Bauelemente)
**broken link removed** Documentation iut Geii Tours
**broken link removed** Electrome
http://www.engineeringlab.com/ kits de composants CMS
**broken link removed** IC manufacturers
http://www-mo.enst-bretagne.fr/~metz/doc_tech/visible/ Doc technique
**broken link removed** Product Change Notifications
Index de circuits intégrés / Bibliographie de revues Espagnole : page Indice
**broken link removed** This page has a lot of old Sanyo data sheets
http://www.nedis.com/semidata/!makeit/frameset_semiconductors.htm
http://www.vdram.com/ Verdier Delbarre RAM
http://www.electronet.com/ ELECTRONET Buyers Database
**broken link removed** COMPO PYRENNEES : Nouvelle adresse de la boutique:
S.A.R.L WN ELECTRONIQUE , 324 rue des Pyrénées - 75020 PARIS ; Tel: 01 43 58 40
48 / Fax: 01 43 58 49 48
**broken link removed** PartMiner + de 14 millions de Datasheets - Gratuit pour les
composants courants - Payant pour les composants obsolètes et pour les informations
stratégiques (circuits de remplacements) ex capexpert que partminer a racheté pour $100
millions.... c'est la plus grande database de composants au monde et elle est gratuite.
http://eehot.com Byrne's Electrical Engineering Hot links
http://www.goldmine-elec.com/ The Electronic Goldmine Web Site
http://www.stquentin.net/ Saint Quentin RADIO
**broken link removed** Free Electronic Component Datasheet Search Service
fabriquants et distributeurs de boîtiers en vrac (vraiment en vrac) :
sarel 0472517282
rolec conform 0142354444
fibox 0478681360
weidmuller 0134503410
phoenix mecano t 0148762020 f 0148751074
bopla (phoenix mecano)
danielson 0442125009
okatron (okw, ....) 0478568000
facelec 0146429999
teko, boss, deltron, rose, zettox, bulte
**broken link removed** Byrne's Electrical Engineering Hot links
**broken link removed** COMPONENTS SUPPLIERS on the Web
**broken link removed** WAFER map
http://noel.feld.cvut.cz/semi/ Databooks Tous composants semiconducteurs
Préfixes des Semiconducteurs (A à Z) (195 Kb)
**broken link removed** AV-Elmak
http://www.ued.net/ Union Electronics Distributors Home Page
http://www.dialelec.com Dial Electronics (UK)
http://www.elec.de/ ELEC.de Elekronikprojekte
http://www.angelfire.com/la/unisourcemarketing/ UNISOURCE MARKETING
**broken link removed** Index of /maker : Classement par fabricants
**broken link removed** Pacific Corporation SemiconBank
**broken link removed** DERF Electronics Corp.
http://www.stuutenbruin.com/ STUUT&BRUIN (The Netherlands)
http://www.techsonicusa.com/ Techsonic- Home
**broken link removed** Techsonic Parts Finder
**broken link removed** Semiconductor Datasheet on the Web
http://www.unitronic.de/ Unitronic
http://207.244.125.74/outlet/surplus.html Surplus Components
http://www.xs4all.nl/~ganswijk/chipdir/index.htm ChipDirectory Home
http://www.xs4all.nl/~ganswijk/chipdir/c/index.htm
Index des Fabricants / Accès aux Datasheets.
Moteur ePanorama/datasheets
**broken link removed** Portail ePanorama
http://electoonix.free.fr Electoonix : Correspondance Prefixe Composant/Constructeur ;
Schematèque, traduction technique 4 langues
http://www.chipinfo.ru/dsheets/ Datasheets by Number
http://www.lookic.com/ Semiconductor Excess Inventory
**broken link removed** Equivalences
http://www.gotronic.fr/ GO TRONIC
**broken link removed** COMELEC
http://www.electrome.fr/ ELECTROME
http://www.datasheetlocator.com/fr/ Datasheet Locator
**broken link removed** E44 Nantes
http://www.electronet.com/ ElectroNet.com - Electronic Components Directory
**broken link removed** Transistorer - IC Index
**broken link removed** Equivalences Transistors
**broken link removed** The Electronic Source Book
http://www.ic-exchange.com WTB or WTS for ICs and Electronic components
**broken link removed** FIND PARTS FAST!!
http://towntarget.com.hk/product/product.html Buy Electronic Components Online
**broken link removed** Cenik
http://electrospec-inc.com/ ELECTROSPEC (EDGE Group)
**broken link removed** Integrated circuits Information
**broken link removed** misc Data Sheets
**broken link removed** Equivalences Composants
http://towntarget.com.hk/towne/main1.html Town Target Tech. - Electronic
E-InSITE Search E-Wiz
**broken link removed** accueil constructeurs
**broken link removed** Search Semiconductors Farnell
http://www.Computer-Solutions.co.uk/ Computer Solutions Homepage ESS
http://www.usbid.com/ USBid Inc. offers a business-to-business online auction to buy and sell
electronic components like memory, microprocessor, SRAM, DRAM, integrated ic chip,
semiconductor. Search database of parts, find and bid in our anonymous secure Internet
ecommerce marketplace.
http://mcu.motsps.com/documentation/hc05/ahc05db.html Motorola Microcontroller ( MCU )
Archived HC05 Databook
**broken link removed** WebEE - The Electrical Engineering Homepage
http://www.industrycommunity.com/tw-ee/index.htm [IndustryCommunity.com] Taiwan
Electrical and Electronic Industry Directory
**broken link removed** Des liens très utiles pour tous les
électroniciens
**broken link removed** Annuaire Mondial des sites Informatiques et
Electroniques (AMIE)
**broken link removed** Hardware Docs
**broken link removed** Farnell
**broken link removed** Philips Semiconductors Search Page
**broken link removed** Philips Semiconductors;
Overview of all application notes
http://www.epn-online.com/ EPN Online: Product News For Design Engineers
**broken link removed** A Survey : Electronics Manufacturers on
the Web
**broken link removed** Databooks Electronics
**broken link removed** Chip Directory
**broken link removed** DANA's Index of Electronic Manufacturers on
the Web
http://www.redactionnel.com/ Le site portail de l'industrie
http://www.arieselec.com/ Aries Electronics - Home Page [connectors]
**broken link removed** NUMERIC PART NUMBERS
http://www.chipdocs.com/ ChipDocs - Datasheets for Electronic Components and
Semiconductors
**broken link removed** TV SAT ELECTRONIC-ELEMENTY
ELEKTRONICZNE - MENU OFERTY
**broken link removed** Electronic Components Company - home of PartFind,
the FREE world wide part locator!
**broken link removed** EngResource Electronic Design Engineers Ref.
**broken link removed** SpinCircuit
http://www.electronique-diffusion.fr Electronique Diffusion tél(Roubaix) 03 20 70 23 42 (mais
10 agences en France)
http://www.findchips.com/
**broken link removed** SMD devices Marking
http://www.repairfaq.org/REPAIR/F_SMD_trans.html SMD devices Marking
**broken link removed** SMD footprint
Marquages des Condensateurs CMS SMD Capacitor Marking
**broken link removed** Search Adobe PDF Online
**broken link removed** Tony Datasheet Catalog
**broken link removed** Farnell France
http://www.digikey.com/ Digi-Key Corporation Home Page
http://www.electronet.com/bbase/linecard/26.htm Digi-Key Corporation LineCard
**broken link removed** Liste Virtuelle de composants
http://www.velleman.be Kits Velleman
ST QUENTIN RADIO 01.40.37.70.74 6 rue de St Quentin 75010 PARIS
h**p//www.rawspace.com/faradnet/company/c0000570.htm SIC-SAFCO
h**p//www.selfco.com tel 03 88 19 15 80 fax 03 88 83 41 81
http://www.selectronic.fr
http://www.radioson.com si composants obsoletes
MTA circuits imprimés 03.88.68.24.34 4 rue de l'énergie 67720 HOERDT
1001 piles à Paris Toutes les piles et Accus
ABPE 1001 01.43.80.33.92 8 avenue Stéphane Mallarmé 75017 PARIS
Gare du Nord 01.40.35.41.76
Nation 01.43.56.80.00
Montparnasse 01.43.27.17.18
ABPE 1001 04.78.62.76.24 34 cours de la liberté 69003 LYON
Milles et une piles 04.76.47.59.37 6 rue de Strasbourg 38000 GRENOBLE
**broken link removed** MEGAMOS
http://www.mbtronics.com composants belgique
Magnétic France 01.43.28.13.99 BP 13 94301 Vincennes Cedex
KN ELECTRONIC 100 boulevard lefevre 75015 PARIS tel.0148280681 Pièces détachées
http://www.alps-europe.com/ Euroindustrie 69, rue du chevaleret 75013 Paris 01.44.23.20.30
Fax: 01.45.82.10.12
**broken link removed** E-Insight
Circuit imprimé haut de gamme
**broken link removed** ECM Circuits imprimés
**broken link removed** ECCO
http://www.e44.com Nantes si composants japonais dûr à trouver
http://www.distrelec.com/ Distrelec - Disdata - Distop - more than 45'000 products online !
http://www.conrad.de Conrad vepex 5000 59861 Lille cedex 9 03.20.12.88.88
http://www.cibot.com Paris si composants japonais
Cholet Composants tél : 02 41 62 36 70
CAP Electronique 167 Rue de la Roquette Paris 11 Métro Philippe Auguste. TV HIFI Vidéo
tel 01.43.72.04.01 fax 01 43 72 51 51
http://www.arquie.fr/ Arquié Composant
http://www.ads-electronique.com ADS
spécialiste RELAIS, TRANSFORMATEURS radio relais 18 r crozatier, tel 0143.44.44.50
fax 0143.28.66.93
O10C Groupement d'une quinzaines de magasins sur la france
O10C Electro Loisirs tel 01.69.02.07.07 33 avenue de la liberation R.N.7 91130 RIS
ORANGIS
Pas mal de composants japonais
