DoraSzasz
Junior Member level 1
Hello...I want the code,in Xilinx....I realized the code in VHDL,but I don't know to traduce in Verilog...
Here is the code....but I have a problem at the counter...After 10 counters appears the number smaller with 10 that the previous number....
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity counter is
port( enable1: in std_logic;
clk: in bit;
reset, reset1: in bit;
bcd_d: out std_logic_vector(7 downto 0));
end counter;
architecture arch of counter is
signal qint, qint1: std_logic_vector(3 downto 0);
signal full1: std_logic;
begin
CNT1 : process (enable1, clk, reset)
-- declarations
begin
if reset = '1' then
qint <= (others => '0');
elsif clk='1' and clk'event then
if enable1 = '1' then
if qint(0) = '1' and qint(3) = '1' then
full1 <= '1';
else
qint <= qint + 1;
full1 <= '0';
end if;
end if;
end if;
bcd_d(3 downto 0) <= qint;
end process;
CNT2: process (full1, clk, reset1)
begin
if reset1 = '1' then
qint1 <= (others => '0');
if full1 = '1' then
if qint1(0) = '1' and qint1(3) = '1' then
else
qint1 <= qint1 + 1;
end if;
end if;
end if;
bcd_d(7 downto 4) <= qint1;
end process;
end arch;
Can you traduce this in Verilog and correct the mistake?
Thank you a lot!
library ieee;
entity counter is
clk: in bit;
end counter;
begin
-- declarations
begin
if reset = '1' then
full1 <= '1';
else
qint <= qint + 1;
full1 <= '0';
end if;
end if;
end if;
end process;
begin
if full1 = '1' then
else
qint1 <= qint1 + 1;
end if;
end if;
end if;
end process;
end arch;
Thank you a lot!
